Old 10-30-2007, 03:12 AM   #1
Evilstealth's Avatar
Send a message via MSN to Evilstealth
Default Grease Question
Is there a grease that will stick on moving parts (eg stick on gears) and not fly off when in motion?
Adam
http://www.rctech.net/forum/electric-road/290595-new-offline-rollout-calculator.html#post5695222 - Offline Rollout Calculator
Evilstealth is offline   Reply With Quote
Old 10-30-2007, 04:22 AM   #2
Trips's Avatar
Trader Rating: 16 (100%+)
Chain lube available at bicycle or motorcycle shops is made to not sling off of rotating parts. It does tend to be sticky and would likely cause some extra drag in an r/c car I'd think...
MARSHAL!!
Trips is offline   Reply With Quote
Old 10-30-2007, 04:31 AM   #3
OK, i heard about ceramic grease being used for greasing gears and moving parts can anyone confirm this?
Old 10-30-2007, 09:25 AM   #4
asw7576's Avatar
of course ..... , I use tamiya ceramic grease for all sort of lubrications : bearing lubrication, enclosed gear box lubrication, gear diff, servo gear, thrust bearing, metal to metal, and many more.
I usually buy them in 12 packs. It's good stuffs.
Old 10-30-2007, 09:36 AM   #5
TryHard's Avatar
You could try a dry teflon bicycle chain lube.... It's what I use on CVD's, works a treat (and no dirt pick-up).
It goes on wet, then you wipe off and it dries onto the surface. First time you use it, needs a couple of applications, but after that re-oating every once in a while is fine. As most also contain Teflon, they are pretty slippy, useful for moving parts.
HiH
Ed
| THard.co.uk | Xray | MuchMore |
Old 10-30-2007, 11:01 AM   #6
MrUnlimited's Avatar
Ask for Pedros at your local bicycle store. They offer different kind of lubrication products like chain lube, grease, etc. I have been using Pedros for man years. http://www.pedros.com/
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 10-30-2007, 09:16 PM   #7
OK i will try the stuff from my bicycle store , i do want a grease that wont pick up any dirt or dust
Grease nsgland Nitro Off-Road 12 08-18-2008 12:30 PM
grease... n3rd420 Rookie Zone 7 05-29-2006 06:10 PM
Tamiya Anti wear Grease or Ceramic Grease..?? TRFTIM Nitro On-Road 6 04-24-2006 11:52 AM
Silicone Diff grease, Axle thrust grease holycow Electric On-Road 3 10-25-2003 11:33 AM
Grease, which is which ?? Wolf Electric On-Road 9 09-25-2002 04:56 AM
