Old 10-29-2007, 10:06 AM   #1
Default battery question
i am using a motor and batteries that have sat for two plus years with no use. Some times i get good power for most of the race, and some times after a few laps my power seems to go flat. Yes i know i need new ones, but i am just curious why this is happening or what may be causing this.
esdjc is offline   Reply With Quote
Old 10-29-2007, 04:17 PM   #2
You've probably got a dud cell that's giving a false peak when you charge it and is discharging prematurely.
Most packs will self discharge over time, and if they get too low, the cells will slowly destroy themselves. After sitting for 2 years, I wouldn't be surprised.
You can confirm by charging, discharging and putting 1000mAh in the pack and letting it set for a week then checking it with a voltmeter.
HTH,
Chris
ckearns is offline   Reply With Quote
Old 10-29-2007, 09:53 PM   #3
thanks
Old 10-29-2007, 09:58 PM   #4
tbeardmore's Avatar
yep
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 10-29-2007, 10:16 PM   #5
gacjr0's Avatar
Trader Rating: 15 (100%+)
The problem could also be with a hung brush or other motor condition.
That would be worth checking into.
gacjr0 is offline   Reply With Quote
Old 10-30-2007, 03:20 AM   #6
mangoman's Avatar
I find with some older packs they tend to false peak sometimes. You may want to keep an eye on what the peak voltage is when it comes off the charger or how many mah it's taking each charge
Hot Bodies Cyclone!!!
www.smaracing.org
www.rchobbies.com.au - www.feralbatteries.com.au
craig mcphee ( WHERE'S MY BEER )
mangoman is offline   Reply With Quote
Old 10-30-2007, 09:31 AM   #7
I will check that too. Any suggestions on decent batteries to buy? I have trinity 3300 right now. Also need a new charger. something that wont break the bank
Got a new battery. Have a question. fastpede Radio and Electronics 0 12-31-2007 08:31 PM
battery question hgoody77 Electric Off-Road 5 02-04-2006 04:05 PM
Battery Question Joe Chaplow Electric On-Road 4 07-28-2005 06:46 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
