Old 05-24-2003, 05:59 PM   #1
Default What's stronger.....
Plastic
or
Graphite
or
Carbon Fiber
broke the steering block on my tc3 and about to buy a replacement. What do you guys suggest?
RoadRat is offline   Reply With Quote
Old 05-24-2003, 06:12 PM   #2
Regional Moderator
R/C Tech Charter Subscriber
Default Re: What's stronger.....
Originally posted by RoadRat
Plastic
or
Graphite
or
Carbon Fiber
for the steering block I would get the graphite
Ko Racer is offline   Reply With Quote
Old 05-24-2003, 06:16 PM   #3
Would it be smart to get the whole graphite kit? Do you know the part number? I'll probably be breaking more parts
Old 05-24-2003, 06:27 PM   #4
Buy the Losi steering blocks, and install them on your TC3. They are much more durable. They are a direct fit.
RC Paperboy is offline   Reply With Quote
Old 05-24-2003, 06:42 PM   #5
Randy Caster's Avatar
Trader Rating: 46 (100%+)
The full graphite kit is a nice upgrade, rc10.com will list the part #'s on all the parts.
Old 05-24-2003, 07:34 PM   #6
I wouldn't get the full graphite kit. I don't think the graphite chassis braces and the graphite shock towers are completly necesary. Besides the composite is better on paved surfaces. I just replace my composite pieces with graphite pieces as they break..... But if you're racing on carpet I would suggest the graphite conversion kit because the graphite is better on carpet. Hope this helps.
racerdx6 is offline   Reply With Quote
Old 05-24-2003, 10:48 PM   #7
This might be a stupid question, but why would composite be better on concrete, better yet, why would it have any effect?
Old 05-24-2003, 11:03 PM   #8
I would go with the plastic steering blocks. I have broken some graphite parts on my TC3 very easily.
Also, I wouldn't recommend the complete graphite conversion. I would only go with the chassis because it takes off the most weight. The other parts are just for show.
Hope this helps
aviaar is offline   Reply With Quote
Old 05-25-2003, 12:08 AM   #9
Super Moderator
Grizzbob's Avatar
The thing about regular composite & graphite-filled parts is that the graphite does make the part stonger & lighter, but also more brittle, so if you hit something hard enough, it would be more likely to break than a regular composite part. And of course with "carbon fiber"(which is essentially graphite) parts, they can't be molded like the others, so the stuff is only good for certain things, like bottom chassis plates or shock towers, things like that, but in those uses the stuff is VERY strong(though I don't know that it'd be any stronger than graphite-filled molded parts)....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 05-25-2003, 01:56 PM   #10
I think the composite would be better on paved surfaces because it flexes more. So it makes you car a little easier to drive and the extra flex is nice because paved surfaces arn't usually as perfect as carpet it. Also on carpet you have more grip so usually a car will handle better and be more predictable with stiffer components. But most of the time only a really experianced driver can tell the difference. I can hardly tell, but than again I'm not that experianced either .
Old 05-25-2003, 03:09 PM   #11
Super Moderator
Grizzbob's Avatar
For some chassis parts I'd agree, but for a steering block I don't think that would make any difference in handling, only in how strong it is....
Bob Seay
Go Pokes!!!
Old 05-25-2003, 03:52 PM   #12
Yeah, I agree. Get the Losi composite steering block. The steering block wouldn't affect handling, except it will hold up better, and a car with a busted steering block doesn't handle very well . You may need to dial in a bit of dual rate because I've heard the Losi steering blocks on the tc3 give you a lot more steering throw.
zx5 vs xxx4g+ which one is stronger straightaway Electric Off-Road 10 02-03-2011 01:54 PM
Stronger 1/10 4WD Buggy Wing pserve Electric Off-Road 19 01-25-2007 06:08 AM
Need a stronger adhesive KSI Chat Lounge 2 05-08-2005 05:57 AM
Is the Revo Stronger/Tougher Than the T-Maxx? Chase Monster Trucks 5 03-02-2005 05:11 AM
Where can I get stronger CV axles..... SuperVF1 Electric Off-Road 1 01-08-2005 05:07 PM
