Old 10-23-2007, 04:42 AM   #1
Dorigecko's Avatar
Send a message via MSN to Dorigecko
Default FF-02 question
Apart from the arms and shafts, what separates an M-03 from an FF-02?
Where can I find the part/s to make it into an FF-02?
Dorigecko is offline   Reply With Quote
Old 10-23-2007, 05:53 AM   #2
The chassis extender- D parts # 50799. Properly set up with a stock motor an FF02 will fly. Don
DLS II is offline   Reply With Quote
Old 10-23-2007, 06:22 AM   #3
Dorigecko's Avatar
that's good to know jason's store has one, just found on ebay.
will they keep up with TT-01s and TB-02s and TA05s?
Old 10-23-2007, 09:16 AM   #4
Some time ago Doug Mertes wrote a test article on the FF02 in RCCA. He said in the article that it would give a stock powered 4 wheel drive TC fits in the parking lot. You must use oil filled shocks. Blue springs, 60wt. in front. Red springs, 40wt in the rear. I used an HPI red sway bar in the rear.( Tamiya sway bar is prefered- I used what I had on hand) I put on a set of TA-02 rear uprights to get toe in on the rear- again what I had on hand. Try a 16t pinion with a CO-27 motor. Also put on a set of adjustable camber rods and tie rods. Driving is very important, FWD handles differently than 4WD. Don't forget to use a ball diff-much easier th drive. Don
Old 10-23-2007, 10:11 AM   #5
Dorigecko's Avatar
I've been using my M-03L, so far with a gear diff and oil filled shocks with the arms virtually flat, on foam xpress tyres, I've had nothing but success.
I don't think a stock motor would quite fit my needs sir. I was thinking more along the lines of retarded 8 x 2 LRP Fusion motor... 16t pinion. Only running Venom 3600mAh at the max i can charge them at (8.5v).
I've got two sets of tamiya sway bars for the TL-01/FF-02/M-03, 24 or so TL-01 arms not including the full set of alloy arms and uprights I have on my drifter, TL-01 rear toe uprights, shafts, outdrives, all that. I have basically everything you said apart from the different springs and oils. Everything to make an FF-02 apart from the D-parts you mentioned.
Front wheel driven cars react much better to one-way differentials. This is a fact. TA03 one way will fit. I've got a TA03/TL-01/M-03/FF-02 ball diff at hand, but it untightens itself. methinks i rebuilt it wrong. need instructions! help me out?
Old 10-23-2007, 02:56 PM   #6
If you can get an 8x2 to hook up- more power to you. As for a front one way, on a 4wd with a front one way when you brake(with a ball diff or spool in the rear) you only have brakes on the rear wheels, the fronts freewheel. If you can drive with no brakes on your FWD go for it. Put a little blue locktite on the " bolt" that holds the ball diff together and replace the thrust bearing assembly with a 5x11 ball bearing- smooth. Don
Old 10-23-2007, 05:47 PM   #7
Dorigecko's Avatar
i've been doing it thus far with no brakes. the M-03/FF-02 gearbox isn't exactly the most efficient gearbox.
nice, thanks for your help.
Old 10-24-2007, 05:28 AM   #8
No problem, good luck in your racing. The look on other people's faces when you beat their 4wd with a FWD is priceless! Don
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
