Old 05-23-2003, 12:44 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Default Soaking belts??
Does anyone soak there belys, if so what in, and what is the purpose of this?
doublest is offline   Reply With Quote
Old 05-23-2003, 12:47 PM   #2
People soak their belts in WD-40 to soften them up more so they are more flexible. This will free up the drivetrain making it more efficient.
-H
Headbanger is offline   Reply With Quote
Old 05-23-2003, 12:53 PM   #3
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
on my tamiya manual it tells you not to soak it
should i still soak it???
will it make it faster?
Calvin Ng is offline   Reply With Quote
Old 05-23-2003, 01:53 PM   #4
Calvin, Do you plan on racing your Tamiya? One thing that I didn't point out before is that soaking your belts in WD-40 will make them wear faster.
Also, depending on how the belt is made, it might make it stretch making prone to skipping if you don't have belt tensioner.
I don't have a Tamiya, so I don't know the specific answer to your case.
-H
Old 05-23-2003, 02:45 PM   #5
Registered User
Calvin Ng's Avatar
i better not soak it then
what kind of sound does it make when the car skips?????
when im going full throttle on my car then slowing down a little and then full throttle again it gives this short slap sound. its hard to explain but is this a skipping sound????
i have a tensioner
its a trf414mii
Old 05-23-2003, 03:08 PM   #6
fatdoggy's Avatar
R/C Tech Charter Subscriber
Yep thats your belts skipping. Use the tentioner, tighten it little by little untill you don't here the sound anymore.
fatdoggy is offline   Reply With Quote
Old 05-23-2003, 03:10 PM   #7
Registered User
Calvin Ng's Avatar
but its a trf414mII
it cant do that
i've ran the belt for more then half a year. is it because its stretched
Old 05-23-2003, 03:13 PM   #8
fatdoggy's Avatar
So the tentioner has tightened the belts the most it can? If so buy new belts.
Old 05-23-2003, 03:14 PM   #9
Registered User
Calvin Ng's Avatar
how long does it take before the belt is streatched????
stock class
Old 05-23-2003, 04:11 PM   #10
stock class
There is no one correct answer. Have you ever heard "Your mileage will vary!"
Change the belt if you think it's too loose and you can't adjust it with the belt tensioner anymore.
-H
Old 05-23-2003, 05:49 PM   #11
Registered User
Calvin Ng's Avatar
the trf has a belt tensioner but it isnt adjustable
i'll just change the belt and see what happens
Old 05-23-2003, 06:58 PM   #12
KINGZJ's Avatar
Send a message via AIM to KINGZJ
The more worn out and stretched it is the better. If it skips a little on decel its not a big deal at all infact I wouldn't worry about it. the only time its a problem is on acceleration. The more worn the belt is the more effiecent the car will be. I soak my TAMIYA belts for weeks in wd40 to make them really free. I have never had one break yet and my belt cars have very free drivetrains.
KINGZJ is offline   Reply With Quote
Old 05-23-2003, 09:24 PM   #13
fatdoggy's Avatar
If you can't feel a noticable difference then don't worry, but if you feel a difference then change them. If you floor it from a stand still what happens, do you hear the sound?
Old 05-24-2003, 01:13 AM   #14
Registered User
My god, are you really a 414 owner? Read your manual. 414 adjust tension by adding washer to tensioner. If you want the adjustable one, buy Square belt tensioner.
Aku-Man is offline   Reply With Quote
Old 05-24-2003, 07:53 AM   #15
seaball's Avatar
Send a message via Yahoo to seaball
i've done the wd40 thing, but now i just use traction compound on the smooth side of the belt when it's on the car. i'll actually wet them prior to a run. seems to be the softest when they are wet.
something that hasn't been mentioned yet, is that the belts can shrink when soaked. infact, i've yet to find something that doesn't shrink them. while this can help a stretched belt remain useable, it also messes up the mesh between the belt and pullies. it isn't noticeable on the layshaft (small) pullies, but i can see it on the diff pullies. look closely with a loose belt. it will actually "bulge" above/below the pulley on the last few teeth due to improper mesh. i would think when running that it may not make a difference, or maybe the belt will stretch under tension enough to match. just something worth pointing out.
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Homemade Tire Soaking raceman17 Electric Off-Road 16 11-18-2006 10:14 PM
XXX-S Belts TigeRyan R/C Items: For Sale/Trade 0 06-09-2006 09:30 AM
CEN belts pro3racer Nitro On-Road 1 08-01-2004 07:06 PM
"soaking" brushes? xray racer Electric On-Road 13 06-21-2004 09:07 PM
Soaking brushes fatdoggy Electric On-Road 22 01-02-2004 09:58 PM
