Old 10-27-2007, 10:00 AM   #16
joe of loath's Avatar
Originally Posted by cm367700 View Post
so what other upgrades/hopups should i get 4 my L4?
i like the sig
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-27-2007, 10:05 AM   #17
Company Representative
Team Kwik's Avatar
Send a message via AIM to Team Kwik Send a message via MSN to Team Kwik
Originally Posted by Larry Brown View Post
If you follow the recommendations above, your car will be capable of making the A main as is without further hopups. The key to going fast is tuning the car to the the track you run. This means adjusting ride height (you will need ride height adjusters if you don't have them), adjusting rear pod dampening via the discs and shock oil, choosing the shock spring that works best (you'll need a set of these as well), front springs, traction compound width on front tire, etc.
Most racers spend months to years to learn proper tuning. I suggest you browse this forum for any thread dealing with 1/12 scale cars regularly, and look for tuning guides to help you understand what each change will do. Rich Chang put together a very nice tuning guide, although I don't have the link. Perhaps someone else can chime in with that. That guide would be an excellent place to start your education.
Larry is dead on with his recommendations as usual. That car right out of the box is more than capable of winning and it's been proven many times. Learn to set the car up to be fast and practice. Being able to run 8 minutes without touching a board is better than any part you could ever buy.
Here is that setup information Larry spoke about, Rich has put together a great guide that's easy to use and understand.
http://richardchang.com/hobby.php?topic=112setup
Have fun with it,
Nick
Team Kwik
http://www.teamkwik.com
Team Kwik is offline   Reply With Quote
Old 10-27-2007, 07:50 PM   #18
cm367700's Avatar
Send a message via AIM to cm367700
Originally Posted by joe of loath View Post
i like the sig
thanks like your's too and thanks for the advice guys
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
("')_("') your signature to help him gain world domination!!!!!!!
JUST DO IT!
cm367700 is offline   Reply With Quote
Old 10-27-2007, 11:21 PM   #19
RichChang's Avatar
Wow - thanks guys. I better get cracking on updating the info on that site (I just saw I haven't touched it since 10/2006!). I am missing info such as servo (angle vs. flat), info specific to T-bar type setups, and some other helpful tips.
Any other info folks want me to add?
-Rich
RichChang is offline   Reply With Quote
Old 10-28-2007, 02:10 PM   #20
cm367700's Avatar
now i have a new problem. I just got a spectrum dsm for my m8 and have range issues and runaways what could be the problem.
oh plus does anyone know or heard about mikes hobby shop? any ways i race there and thought that might help
www.mikeshobbyshop.com
(\__/)
JUST DO IT!
Old 10-28-2007, 02:34 PM   #21
Try the Radio and Electronics forum under General Forums.
Larry Brown is offline   Reply With Quote
Old 10-28-2007, 07:10 PM   #22
chris moore's Avatar
Trader Rating: 88 (99%+)
The only reason I can think of for range issues is the rec or tranmitter module are not working correctly. Check the rec to be sure it has the correct wire, and that its not loose where it exits the rec. If nothing looks out of place try and see if you can bind with another rec and see if you still have the same prob. after you figure out if its the rec or the module send the non-working part in to Horizon and thay will fix it np. Now the runaway prob; that usually only happens if you did'nt hold the transmitter trigger in the full brake position when you bound the rec to the transmitter. Rebind and try again, heck rebinding may even fix the entire problem.
chris moore is offline   Reply With Quote
Rookie Black_Widow Singapore R/C Racers 0 07-18-2006 07:04 AM
Not Quite a Rookie, What's Next? Hawk6 Rookie Zone 45 02-10-2006 02:25 PM
rookie in some need rcrookie Rookie Zone 6 02-04-2006 08:46 PM
MORE Rookie Help! tandsbc Rookie Zone 1 08-21-2005 07:11 PM
Rookie Help! tandsbc Rookie Zone 8 08-20-2005 02:52 AM
