Xray T2R, 2100 mah 2c LiPo, and Mabuchi power: Tech tips and Tricks
#31
I keep telling people to slow down to go faster, but very few people listen.
That's part of the reason for using Mabuchi/Duratrax motors.
Most of the time it's easy to pass out-of-shape-corner-overshooting cars; but sometimes they hit you, .
#32
Thats what happens at the club gacjr0 and myself race at there is about 4-5 of us faster racers in the class and then a buch of other racers with overpowered cars mixed in the class. Gary is right about the out-of-shape-corner-overshooting cars; that sometimes they hit you. This is good for clubs everywhere makes racing more fun and even for everone not just the guy with the best stuff money can buy
#35
Yeah, I thought about putting a stock motor in for the main but decided to leave it alone. This week I might try running a stock, 19, mod and see what happens.
#36
I believe the silver cans are 32T...that is what was told to me, plus my motors all have 32T printed on them. I use this motor in Porsche Cup racing in a F103GT chassis.
Have any of you guys played with the black can? I heard that it is just as durable....just a lot faster...
#39
Your going to get a kick out of this, a kyosho mini inferno weighs around 950 grams w/ the alum goodies that most people like to run. Now, I'm pretty sure that a mamba 25 w/ a 8kv motor will put out enough power to push a mini inferno around at 30 m.p.h. w/ a 2s lipo. Now, I'm pretty sure that if you dropped a mamba 25 esc & a mamba 8000kv motor in the car you would lose 100+ grams of weight. which would put you right around 1000 grams. It might take a little work to mount the motor, but it would shave a ton of weight.
#41
I will be racing tomorrow with the same stuff I've posted on; and be testing the differences between Duratrax/stock/19/mod motors on the same car.
Gary
#42
Headshot, I think you'll find your answers about silver/black can motors in the Silver can thread. That's where I learned the most about mabuchi and mabuchi-style motors.
#43
Update: ran a Trinity handout stock motor instead of the duratrax.
Result: no gain.
Conclusion: I am not a really good driver. It takes a bit more setup time than I took to adjust for more power. The little 2100 mah 18c might be at its limit with this powerplant in a tc, the power went really soft and the pack was at 140+ degrees while the motor was ok at the end of a run.
Result: no gain.
#44
you may have to invest in a higher capacity pack. what weight is your current one? i found a 50c heli 4900mah pack thats 244g, and thats still less than a 4200 stick pack. the only problem would be it's size, but it was the power to deliver loads more power to your motor, since you could upgrade to a mod or something. you'd still have a light car, and it would be half as fast again.
http://www.e-rc.co.uk/shop/evo-4900mah-2s1p-p-68.html
#45
Yeah a lot of people don't how much harder it is to setup a faster car, makes you respect the mod drivers a tad more.
Drew.
