Old 05-22-2003, 11:59 AM   #1
Default Tire/Wheel combo's......
Can someone explain how to chooise the right tire and wheel combo for the TC3?
Thanks.
RoadRat is offline   Reply With Quote
Old 05-22-2003, 12:23 PM   #2
Send a message via AIM to Johnnytc3
depends on the track surface and temperature
Johnnytc3 is offline   Reply With Quote
Old 05-22-2003, 12:26 PM   #3
Thanks Johnny....get real basic with me here though.....
how do i pick wheels and then match tire sizes to it.
for example, the wheels I have are sized:
Total Diameterincluding lip) 2.07" or 52.5mm
Diameter: 1.92" or 48.6mm
Width: 1.03" or 26mm
First, will this size work on the TC3 190mm and 200mm
And what tires will fit?
Thanks!!!
Old 05-22-2003, 12:29 PM   #4
Oops, also how do I know the wheels will actually mount on the tc3? What kind of mounting pattern does the tc3 have?
Old 05-22-2003, 12:33 PM   #5
basically most wheels and tires for the touring car are 24mm and the tc3 uses a standard hex, so by defualt it should fit the tc3. dont buy wheels with an off set. Dont worry about the diameter and such, just know that 24mm tires will work on all 24 mm wheels. and yes it will work with 190mm bodies but on 200 there might be a lil body gap between the wheels.
Old 05-22-2003, 12:34 PM   #6
newracer's Avatar
R/C Tech Charter Subscriber
most touring car tires/wheels are 24 and 26mm width and have a standard hex adapter that will fit the TC3. Some have different offsets, I am not sure what offset the TC3 uses, if any.
newracer is offline   Reply With Quote
Old 05-22-2003, 12:40 PM   #7
tc3 uses a 0 offset
Old 05-22-2003, 12:53 PM   #8
So Johnny, will a 26mm wheel work?
Old 05-22-2003, 12:55 PM   #9
yes it would what kind of surface and temp will you be running on?
Old 05-22-2003, 12:56 PM   #10
some 26mm might rub on the ballcups so you might have to get a offset wheel
Old 05-22-2003, 12:58 PM   #11
cool. thanks a lot for all the help!
Another 1/8 Tire and Wheel LOT manynitros R/C Items: For Sale/Trade 10 06-28-2008 07:04 PM
b4 tire and wheel lot . snopro31 R/C Items: For Sale/Trade 11 10-28-2007 12:08 PM
1/8th tire/wheel lot NIP rccars4scott R/C Items: For Sale/Trade 3 06-02-2007 09:49 AM
2.o wheel/tire derricklong38 Electric Off-Road 0 04-11-2007 07:31 PM
Rollout Combo's Kennedy Australian Racing 1 09-16-2003 07:35 PM
