Old 10-17-2007, 05:20 AM   #1
Default Has anyone killed their brand new lipo?
Just got my brand new Trakpower fully setup today. First few runs was fine then CRASH!!! a heavy crash kill my lipo. Has anyone killed their brand new lipo before? what brands of lipo that has a strong case to reduce the risk of killing the cells that u know of?
andy85 is offline   Reply With Quote
Old 10-17-2007, 05:36 AM   #2
d4_racer's Avatar
Send a message via MSN to d4_racer
the orions sell hard case lipos.
how exactly did the lipo get damaged though? puncture? denting? pics? or was it just the g-forces
\____
==\_\___===___ | *HPI Baja SS kit;*
==(@)\_______\(o) +UNDER CONSTRUCTION+
out of racing, but a proud marshall, lol
d4_racer is offline   Reply With Quote
Old 10-17-2007, 05:57 AM   #3
Regional Moderator
Mark Mixon's Avatar
Default Lipo
I left the Lipo hooked to the charger without a power supply attached...oooops!...It discharged the battery down to zero and now I have a very expensive paperweight. Learn from my mistake...disconnect the battery from the charger when not charging.
Mark Mixon is offline   Reply With Quote
Old 10-17-2007, 06:13 AM   #4
Trader Rating: 16 (94%+)
I killed a 3200 by hooking it up backwards to the speedo. Snap, Crackle, sizzled......
Luckily the speedo and motor were ok, but the battery was burned toast. I have to give credit to Novak for designing the GTB Speed Control and BL Motor so well.
After that happened, I pulled the Orion 3200 apart to see what had happened. I found that the flat-wire leads that go inside each of the two lipo cells were burned in half.
That day I learned a very quick $90.00 lesson on how NOT to hook up a LiPo battery. Next, I marked my battery and car clearly with a Silver marker so I will always remember which side is positive + and which side is negative -- .
kn7671 is offline   Reply With Quote
Old 10-17-2007, 06:53 AM   #5
billjacobs's Avatar
Trader Rating: 55 (100%+)
Default hooking up lipo backwards
kn7671: That is a safety feature in the orion packs. The terminal acts as a fuse. If the lipo fuse didn't blow, the gtb would of burned up, and the pack could have very likely caught fire for a few seconds (after thermal runaway.) This is why the kokam cells are so well regarded, they have SAFETY built in.
billjacobs is offline   Reply With Quote
Old 10-17-2007, 07:03 AM   #6
no puncture only a long hard scrap on the edge of the lipo taking off some of what seems to be plastic case!!! =[ it was pretty much at top speed when it went onto the sides and flipped countless times then crashing down...god that hurts my wallet hahah
owells...time to move on to another pack...gonna try team orion, n see how tough it really is hehehe =]
Old 10-17-2007, 07:53 AM   #7
I've broken an Orion 4800 through repeated crashing. The tube for the banana plug broke apart at the solder joint inside the battery, but it was easy to remedy once the case was pulled apart.
The case is just stuck on the packs with servo tape... Constant pressure prying the top and bottom halves will open up the pack so you can check out the internals.
Chris
ckearns is offline   Reply With Quote
Old 10-17-2007, 08:15 AM   #8
d4_racer's Avatar
bad luck guys.
i'm sure my new idea will work for keeping my lipo's safe:
also there is foam tape/stuff on the inside side of the metal to hold the lipo in place.
this stuff is only half mm metal so i may need to upgrade to 1mm like i planned. but still its pretty tough and it'd take ALOT to scrape away all the metal exposing the pack or a fair bit of brute force to puncture the metal with a object.
what ya think? not bad for a 2min job
\____
Old 10-18-2007, 04:17 PM   #9
good job man....lipos should come in well protected cases to save our wallet =] hehehe
Old 10-18-2007, 04:38 PM   #10
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
I've left a Li-Po pack hooked up on the ESC for the fan to cool off the ESC and forgot it. $80 went goodbye. 2nd time the flat metal broke inside the packupon a scrape and adios to that pack. Both times were Orion 3200s.
RC America - Xray - Hudy - Gravity RC - KO Propo - Super Rad Graphics
Mr. Shookie goes home 10-06-08. Bill Levinson 4-14-15
F. Mendoza is offline   Reply With Quote
Old 10-18-2007, 04:46 PM   #11
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
You must have the worst luck with those.
Man both of mine are still in top shape.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Steve Irwin the croc hunter killed!!! Got Xray? Australian Racing 66 09-09-2006 01:04 AM
this could get you killed lordraptor1 Other Items: For Sale/Trade or Wanted to Buy 10 04-15-2006 10:37 PM
RS5 Killed 5 of my plugs Slammed Onroad Nitro Engine Zone 23 04-15-2004 01:13 AM
killed my speedy scorpia Electric On-Road 1 03-18-2004 06:04 AM
