Old 10-16-2007, 11:33 PM   #1
bullfrog_racer's Avatar
Default Run Time + Gearing ??
HI guys was wondering if anyone can offer some experience.
Am new to electric racing and was wondering if anyone can tell me a few things, I have a HB Cyclone S and a ratio of 2.473 running 81 Spur and 52 Pinion and a roll out of 51mm. We run on a large track using silver cans and limited to 1500mah nicads. I race against Tamiya TA05/416 etc, T2's, Yoko's, TC4's etc
Am looking to make some changes to get better acceleration and a bit more speed and runtime (I only have about half a lap left in the batts after a run), I don't keep up off the start line and don't seem to have the legs on the back straight, I don't think its going to be easy though!
1. If I lower the internal ratio to 2.16 will this give me better acceleration?
2. With an internal Ratio lowered to 2.16 I can still run the same rollout of 51mm would my runtime remain the same/less/more?
3. Would a front spool save speed/runtime?
4. Are thier any tricks to getting more runtime?
Thanks in advance!
Team Associated 12R 5.1 5.5T :: Team Magic G4S - OS 12TZ :: Mugen MBX5T - OS VB V Spec
bullfrog_racer is offline   Reply With Quote
Old 10-17-2007, 04:13 AM   #2
Uga
Uga's Avatar
1. Yes
2. More
3. No idea
4. Probabbly
You're welcome
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 10-17-2007, 04:38 AM   #3
Shop Owner
nnick's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to nnick Send a message via MSN to nnick Send a message via Yahoo to nnick Send a message via Skype™ to nnick
3. Spool gives you better braking, slower on turns compared to one way so I guess runtime will be almost the same as diff but less than one-way
4. Charging with less Amp, use less timing (everything costs speed though )
Nikolakopoulos Nick
RC RING
The #1 source for all your electric needs www.rcring.eu
Enjoy RCing....
R/C Tech #82
IRT #123
Don't practice until you get it right. Practice until you can't get it wrong
Team Xray T4'17, Team Xray X10'18, TOP Racing Rebel
nnick is online now   Reply With Quote
Old 10-17-2007, 04:47 AM   #4
LOSI123's Avatar
Trader Rating: 63 (100%+)
dont run 51mm rollout!,
run 45 - 48mm
51 is to high
No! changing internal ratio but then adjusting gearing back to get 51mm will just end up the same in terms of the load on the motor .
people who say otherwise dont really have a clue in my opinion
i ran 540 silver can for ages on large outdoor track , i tryed 50-51mm for a long time, and you are better of freeing up the drive train / bearings etc, and running around 47mm , trust me!
LOSI123 is offline   Reply With Quote
Old 10-17-2007, 07:43 AM   #5
i can vouch for the above he knows what he's talking about. btw thanks for all your help when is the next meet hopefully i'll have my 1:1 back
khubner is offline   Reply With Quote
Old 10-17-2007, 12:33 PM   #6
Excellent, great to get some ideas, I will try the suggestions and experiment a bit,
Is it true if you charge at a higher rate you get more punch? does it make much difference on a Silver Can?
I will look at lowering the ratio and rollout and see what happens.
All ideas appriciated!
Gearing a B4 Interceptor Electric Off-Road 8 01-26-2008 11:34 PM
Gearing BayArea101 Rookie Zone 7 01-21-2007 11:25 PM
TC3 Gearing Ridge_Racer Rookie Zone 6 01-31-2005 02:37 AM
Gearing/Battery Time/Motor Temp Aluma Electric On-Road 3 01-20-2003 01:40 PM
run time VS tweak time bigbutstupid Electric On-Road 7 06-16-2002 04:40 PM
