Old 07-31-2003, 04:25 AM   #31
I try to follow this and found my PS just blow up and can't find the replacement of the part.
Rhes4 is offline   Reply With Quote
Old 07-31-2003, 11:53 PM   #32
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
you have to go to more specialized stores
not radio shack and stuff
did you ask if you could order em??
Calvin Ng is offline   Reply With Quote
Old 02-19-2005, 08:46 PM   #33
GReddy's Avatar
Send a message via AIM to GReddy
does anyone noe of any other sites that has more pics?
GReddy is offline   Reply With Quote
Old 02-19-2005, 10:29 PM   #34
bender's Avatar
This link: http://www.rctech.net/forum/attachme...postid=1397868 show the inside of my psu so you can see how it's set up.
The best instructions and tips can be found at the rcracechat forum.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 02-19-2005, 11:15 PM   #35
nimble's Avatar
In the design of our new TwoLane
we were tempted to use computer power supplies, you can often find them real cheap. The few that we tested were found to be unreliable. I think someone else had mentioned they really want/expect a large current draw on the 5v and/or 3.3V output to be stable, the ATX version have an unfriendly electronic on/off switch.
I have a fair number of 12v 8-Amp power supplies that we ended up not using in our chargers, since we went to 12amps. I can sell these fairly cheap ($15) if anyone is interested. They are open-frame supplies, so they really must be put into a box of somekind.
Here is a link to them 12v power supply
I suppose I should post something in the for-sale group?
nimble is offline   Reply With Quote
Old 02-19-2005, 11:57 PM   #36
GReddy's Avatar
my 12v output is only 4.2 amp
im guessing that wont be enough right? and is there a way to boost the amperage?
Old 02-20-2005, 12:44 AM   #37
nimble's Avatar
If you're using it for a battery charger to charge at 5amps, 4.2 wouldn't be enough. It might charge at 4amps, then again, PC part makers overrate their stuff, so it might not. It certainly doesn't seem worth the hassle to use a PC supply if it only puts out 4amps.
If you are desperately cheap, I have a very small power supply that outputs just 4amps you can have for free
Old 02-20-2005, 12:46 AM   #38
GReddy's Avatar
really i can have it for free?
Old 02-20-2005, 10:29 AM   #39
nimble's Avatar
That's what I said. Go to our website to get a direct email contact, and then email me your address.
Old 02-20-2005, 10:55 AM   #40
GReddy's Avatar
k email sent thank you very much
Old 02-20-2005, 11:14 AM   #41
Soviet's Avatar
find a good EPS12 server-type Power supply that puts out over 20 amps...then you'll have ZERO problems, and more capability than a rivergate Bulldog for 1/3rd the $$$.
Plus...if you need a guide...here you go!
http://www.marcee.org/Articles/PCPowerSupply.htm
"You don't get hurt racing little cars..."
-Me
Soviet is offline   Reply With Quote
Old 02-20-2005, 12:02 PM   #42
revzalot's Avatar
Thanks. That's what I was looking for.
revzalot is offline   Reply With Quote
Old 02-20-2005, 12:04 PM   #43
revzalot's Avatar
Has anyone used a AT power supply. It already has a built in switch. If so what kind and specs. Thanks.
Old 02-20-2005, 04:15 PM   #44
imjonah's Avatar
Default Easy and not so easy
I took an AT style power supply (mechanical switch) and simply gatthered together some of the 12 volt wires for the positive line and some of the black ground wires for the negative and taped off the rest. I think most of the PC Power supplys that are 6 x 6x 3.5 put out about 10 amps.
imjonah is offline   Reply With Quote
Old 02-20-2005, 05:37 PM   #45
GReddy's Avatar
do you have to use resistors? what happens if you dont use them?
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
Computer power supply semper Australian Racing 79 11-23-2007 12:35 PM
Converting a PC Power supply to use with RC Charger aN4rK1 Electric On-Road 32 03-03-2006 09:11 AM
computer power supply hpipro321 Electric On-Road 4 09-01-2005 01:25 AM
Converting Computer Power Supply. Resistors Q's Calvin Ng Electric On-Road 12 02-19-2005 08:47 PM
