Old 01-16-2008, 01:36 PM   #61
Default Front End:T*Star12
Works fantastic.
The picture say more than 1000 words
Alf
removed the image, since this design is not what i work on now
link is:
http://home.no.net/alf50/03_front_TStar12.JPG
alf.skaar is offline   Reply With Quote
Old 01-16-2008, 03:01 PM   #62
Chemical X's Avatar
Trader Rating: 16 (100%+)
Alf,
Very interesting design. Is there a reactive-caster motion in the suspension or does it stay static?
Chemical X is offline   Reply With Quote
Old 01-16-2008, 03:49 PM   #63
Originally Posted by OscarF1 View Post
Hi,
when creating holes and gaps to make things lighter you should
be thinking in lines between points of stress.
Connect the ponts or holes that support components
en greate gaps between those lines.
You also should be aware of the post stamp effect.
It is easy to break somthing when holes line up.
I realy like your effort to continue the 1:12 evolution.
For a few months I own and drive a 1:12 car but got
already som ideas for a simpeler concept.
In 1:10 touringcars it is a great benefit to move the battery as much to center as possible.
I assum that is the same with 1:12.
In the concept i am thinking of,
the battery will be placed as 4 cells in the middle of the car,
and the T-bar placed to the outside of the car.
Anyway this winter I wil make some prototypes to test on the track.
There is a car that is designed with the cells down the middle. The company is called Diggity Designs should be able to google it for thier web address
Bubonic-X is offline   Reply With Quote
Old 01-18-2008, 02:28 AM   #64
Originally Posted by Chemical X View Post
Alf,
static
Alf :-)
Old 01-18-2008, 02:13 PM   #65
Well if the upper arm moves but the lower arm does not your going to get some reactive caster unless you are at 0 degrees caster.
Interesting design...it appears you are using the fiberglass plate as both the upper arm pivot and the spring. I assume you have different plates for different spring rates, camber settings, and caster settings?
Old 01-18-2008, 04:03 PM   #66
looks cool and looks like it would be worth a try
Leon McIntosh
PRO-LINE--XRAY--RCAmerica--FX Engines--NitroPro Fuel--Kustom R/C Graphics--Schelle Racing
******* DialedSetups.com ****** Check it out!!!!!
punkracer24 is offline   Reply With Quote
Old 01-19-2008, 09:24 AM   #67
Uga
Uga's Avatar
hmm, as I understand, the upper arm moves only on flex. It sure looks interesting, but what exactly that gives to the handling? And isn't it a bit fragile..? Alf, could you explain to me (and other dummies) your concept?
-=Xray XB4=-
-=Xray XB8E=-
-=Schumacher Cougar KF2=-
-=Awesomatix A800X=-
Racing in Latvia
Uga is offline   Reply With Quote
Old 01-20-2008, 05:49 PM   #68
NO i use normal spring to, the flex plate is 1.6 mm fiberglas same as used for t-bars, this is the on one i have test sow fare.
Yes diffrent flex plates for different Caster, Camber.
Alf :-)
Old 01-20-2008, 06:00 PM   #69
Yes the flex plate, bends / flex at max suspension i moves 0.2 mm then the chassis will be down in the carpet, sow it will be les than that.
The test i have done now shows me that i handels fantastic.
Ther are ony to piviot bols, and no play in the arm
I have hit the wall hard and have not broken any parts sow fare.
More testin have to be done.
I can be that the lower arm take most off the hit.
Runing a normal AE fronte end i have never broken any upper arms
it is always the lower arm that break.
Alf :-)
Old 06-13-2008, 02:04 PM   #70
I have update the car for BL
Alf :-)
Old 11-25-2008, 05:06 AM   #71
Som updated images :-)
Alf
Old 11-25-2008, 05:44 AM   #72
MartinSorlie's Avatar
Fantastic work Alf, it'll be interesting to see it at the next race
Jeg begynner å kjøre touring igjen nå, men hvis du begynner serieproduksjon så må du si fra, da skal jeg kjøre 1:12 også
Martin Sørlie, 1985, R/C since 1995.
TLR - Spektrum
www.teamsmallsize.com
MartinSorlie is offline   Reply With Quote
Old 11-26-2008, 02:58 AM   #73
MartinSorlie
The car is going extreme well.
Not a single t-bare broken. :-)
12 scale is the biggest class in Norway for the moment
Alf
Old 11-26-2008, 01:08 PM   #74
Originally Posted by alf.skaar View Post
MartinSorlie
Alf
I'm moving to Norway!!!!
Crashby is offline   Reply With Quote
Old 11-26-2008, 04:16 PM   #75
Come on, we have plenty of room for more!
TLR - Spektrum
