Old 11-04-2007, 12:34 PM   #46
Originally Posted by GreaseMonkey View Post
I'm still having trouble trying to work out the front suspension.
I understand the delrin pieces have fluid in them for damping. Is the t-bar type piece the spring or is there a spring inside the delrin piece like on any other type 12th scale? If the t-bar type piece is the spring, how does it work? If it's not, why is it there? Is it just so the upper arms are longer to reduce negative camber gains under loads?
Could you show a photo of the front suspension from a different angle so I get a better look at it?
GreaseMonkey
Here is a picture after i cut of about half of the cup.
Alf :-)
alf.skaar is offline   Reply With Quote
Old 11-04-2007, 02:31 PM   #47
GreaseMonkey's Avatar
Thanks Alf. I worked it out after you explained it. Do you notice a significant improvement with the damping and longer upper arms?
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 11-04-2007, 02:49 PM   #48
All the test i have done until now show me that i works.
I have test with 20 000 Silicone Oil and this is very hard.
I can drop the car from 10 cm and it instantly are damping
the front, this is to hard damping, but i have to test the
extreme to make sure that i work and it do, this
are removing steering, i will test whit something thinner.
The goal is to make more steering whit out traction rolling.
Alf :-)
Old 11-04-2007, 05:03 PM   #49
rtherbe's Avatar
Nice work Alf I am not a 1/12 guy, but it looks like a great platform to "Mod" on.
rtherbe is offline   Reply With Quote
Old 11-05-2007, 05:40 AM   #50
rtherbe
Som update after the second race whit the T*Star12
My car is going great!
I ended up setting fastest lap with 13:78 well until the last touring final
the boy (Helge Johansen) that was leading did a mistake and was pushing like crazy
and he did 13:74 and the boy that had the lead (Adrian Berntsen) dump hard, and helge
dump to, but he overtake Adrian, but i think Georg ended up wining :-)
Sow the car is fast and still no broken t-bar works great
Alf
Old 11-09-2007, 04:13 AM   #51
I now have BL in the car i can post pictures of it if any one whant to se
Alf
Old 11-11-2007, 02:11 PM   #52
Default Upper Arm
I'm working on a new upper Arm, this are early prototype drawing.
drop the arm on nothing to adjus.
Alf
Old 11-19-2007, 03:37 AM   #53
Vesa's Avatar
Send a message via ICQ to Vesa Send a message via MSN to Vesa
Looks nice Alf!
V @ V-Dezign
Sponsored by: V-Dezign | Nosram | Reedy | Black Art | TQ Wire | Horizon hobby | Xenon Racing | Badger airbrush | RC-Trim.com
Web - www.v-dezign.net | Facebook - www.facebook.com/vdezign
Vesa is offline   Reply With Quote
Old 11-19-2007, 10:06 AM   #54
OscarF1's Avatar
Like this ?
OscarF1 is offline   Reply With Quote
Old 11-19-2007, 11:40 AM   #55
joe of loath's Avatar
mmmmmm redness...
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 11-19-2007, 02:49 PM   #56
Originally Posted by Vesa View Post
Looks nice Alf!
See you in Sweden
Alf
Old 11-19-2007, 02:57 PM   #57
Originally Posted by OscarF1 View Post
Like this ?
This is from the scalpe, and this is the lower arm i think, i'm working on a fix upper arm.
Sow i have to say no
I think that i will run the CNC in the morning, i have done a small change for the
battery holder on my car, and made som spare parts for the race in Sweden
this weekend. sow i i'm ready to make som proto type parts
What do you all think off a fix upper arm ?
when you change the caster you change the arm, and when you change
the camber you change the arm.
Alf
Old 11-20-2007, 08:13 AM   #58
OscarF1's Avatar
Could work well.
Maby both sides out of one piece.
You could make it like a bridge.
Les parts is better!
Old 11-20-2007, 05:31 PM   #59
OscarF1
I whas thinking one part and it will fit on both sides,
if i make a bridge and one side are breaking, then you will have to replace both
sides.
Alf
Old 11-28-2007, 01:49 AM   #60
I tested the demping and the fix upper arm and the car feels very precise and stable.I used the CRC "red lube - approx 1000wt" this is still too thick since this track doesn`t have any traction. But i was very surprised how good it works, slack in the frontend is not a good thing, i will do som changes to the design and try to make som cut out to make the upper arm softer.
Alf
