Old 05-21-2003, 03:15 PM   #1
Default Would this power pack work???
I have a KO Propo Bx-212 charger and i need a portable power source to power it. With this be good to charge 2 packs of 2000's and 1 pack of 3000MAH
http://www.canadiantire.ca/assortmen...=1053551358006
Thankx
tl01 1989 is offline   Reply With Quote
Old 05-21-2003, 03:26 PM   #2
sosidge's Avatar
Link doesn't work right.
Old 05-21-2003, 04:41 PM   #3
it does for me here are the details anyhow
Motomaster 300 Amp Power Pack
300 cranking Amps
Equipped with 12 V accessory plug
Can be used as both a booster pack and a 12-volt DC power source
Manual on/off switch
Old 05-22-2003, 04:48 AM   #4
sosidge's Avatar
No, that's an emergency car starter/charger, I doubt the 12v supply is rated for many amps, also it won't be a smooth supply.
Old 05-22-2003, 05:44 AM   #5
Ok then what do you sujject that doent weigh a ton
Old 05-22-2003, 06:06 AM   #6
komkit's Avatar
Send a message via ICQ to komkit Send a message via AIM to komkit Send a message via Yahoo to komkit
300 cranking Amps
So, I assumed you do not have an access to AC power. Am I correct?
Is this power pack you are talking about a self contain 12VDC Battery? If that the case, I don't really understand what Sosidge is talking about "it's won't be a smooth supply".
If the Battery doesn't have a smooth DC output I don't know what else will. Not even a $21,000 switching power supply that I am using in my office as smooth as Battery.
The bottom line is, if the power pack you are talking about contain 12VDC battery and have a direct output from Battery.. Go for it.
CFX Paintworks - The Track
komkit is offline   Reply With Quote
Old 05-22-2003, 06:10 AM   #7
you ae correct, i do not have access to AC power. Im not to sure weather it has a 12v battery but im assuming since is it a "power Pack" that powers 12V accessories (cooler,fan etc. it must have that power on board
Let me know
Old 05-22-2003, 06:11 AM   #8
a pic for those that the link didnt work
Old 05-22-2003, 06:20 AM   #9
komkit's Avatar
Let me know
Okay, now...I am pretty sure the unit you are talking about is a self contain BATTERY.
For you to charging your R/C packs? Should be just fine. I would say you will be able to charge your packs ummmmm maybe 10 packs @ 4.5 -5 amps before the voltage starting to drop.
That is depens on what the size of the battery that is installed in that power pack. I can not calulate how many packs per day you can charge with this power pack..
Unless I know the size of the battery that was in it.
Old 05-22-2003, 06:25 AM   #10
10 packs thats more than great its fantastic!! . ill go to the store and check it out
Thankx
Old 05-22-2003, 06:26 AM   #11
komkit's Avatar
Okay, I see that now.. Sure, I have seen many people using the same type of power pack..
It a self contain 12VDC battery.
Like I said I won't be able to tell you how many packs you can charge or how long does gonna last before you needed to charge to 12VDC battery. the unit like this usually come with the wall charger so you can plug them overnight or something.
I loose signal or power to my servos, They Stop responding then work again ,,, help patrick21x Radio and Electronics 8 08-08-2008 10:44 AM
Will this power supply work? Jynx Electric Off-Road 27 11-07-2007 01:39 PM
Xray M18 + Power Pack - FS or FT vb6rox R/C Items: For Sale/Trade 9 11-13-2005 05:52 PM
Converting Computer Power Supply. Who got it to work? Who didnt? Calvin Ng Electric On-Road 47 02-20-2005 08:17 PM
Xray M18 Power pack Aku-Man R/C Items: For Sale/Trade 3 03-19-2004 11:27 PM
