Old 05-20-2003, 10:48 PM   #1
Carbon_Fibre3's Avatar
Default Stock Motor Brushes
Hey guys, i was at my lhs not to long ago and i asked for some advice on what brushes work well in stock motors, i was given these variable timing brushes. Are they worth running? They have a cut across the brush face, dividing it into 1/ and 2/3 portion (roughly). If i were to run these, which way should the cut face? i currently run reedy 767's among others, so is it worth using these? or shoudl i fob them off onto my friends motor :-)
Rob Storey #5
Carbon_Fibre3 is offline   Reply With Quote
Old 05-21-2003, 02:58 AM   #2
TWiZTiD's Avatar
if they are the integy ones then yes just make sure you put them in the right way
TWiZTiD is offline   Reply With Quote
Old 05-21-2003, 03:56 AM   #3
is there a right way?
Old 05-21-2003, 04:42 AM   #4
TWiZTiD's Avatar
The larger cut out part is the trailing edge of the brush
Old 05-21-2003, 05:16 AM   #5
ok thansk
Old 05-22-2003, 11:16 PM   #6
kaizen's Avatar
Have you tried the new Trinity Crosscut brushes? Anything to report on these? I have been using them, but haven't been happy with them -- thought they were basically 4499s with diagonal serrations, but...
Also, heard of using 767s on positive with 797s (serrated with bullet hole) on negatives. Anyone have any success with this combo?
Thanks.
kaizen is offline   Reply With Quote
Old 05-22-2003, 11:23 PM   #7
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I dont think that the cut brushes are legal at most tracks. They basically advance the timing on stock motors, and will give more RPM's because of that.
Has anyone tried the Niftech brushes made for a specific comm size?
Old 05-25-2003, 04:55 AM   #8
TWiZTiD's Avatar
I have tryed the cross cut brushes they work really well but the cross cuts only last one and a half runs so i cant see the point
Timed brushes are roar legal but I dont think Integy timed brushes are the fastest brushes around I would run Putum green/Blue or reedy 767 brushes
Old 05-25-2003, 05:01 AM   #9
i currently run reedy 767, but have the timed ones in my brush box.. so i guess i'll fob them off onto my mates motor. :-)
Rob Storey
Old 05-25-2003, 11:27 AM   #10
Mr. MR4's Avatar
What is the difference between the laydown Reedy 766 (Actron) and Reedy 767 Serrated Brushes??
Mr. MR4 is offline   Reply With Quote
Old 05-25-2003, 12:55 PM   #11
The way I understand it 766 is more of a torque brush with mimimal wear on the comm.
767 is more of an RPM brush with more comm wear. I use 767 almost exclusivly. I do not re serate them thought, I seem to get more power full face.
David Root is offline   Reply With Quote
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
19 TURN MOTORS, STOCK MOTORS, 767 BRUSHES, F BRUSHES, 2 MOTOR CASES LOSIMANJRXS R/C Items: For Sale/Trade 47 10-21-2006 06:06 AM
What Brushes Do YOU Use In A Stock Motor StasI Australian Racing 17 11-04-2005 05:40 PM
Stock motor brushes impdog Electric On-Road 29 06-09-2005 12:53 PM
Stock Motor Brushes gporta77 Electric On-Road 1 11-04-2003 05:56 PM
