Old 10-13-2007, 12:33 AM   #1
Default GTB Lipo cutoff
I'm making the switch from nimh to lipo and was wondering how to activate the lipo cutoff on the GTB, the instructions on Novak's website doesn't make any mention of it. Any help would be greatly appreciated.
_pilot_ is offline   Reply With Quote
Old 10-13-2007, 12:40 AM   #2
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
there isnt one on the GTB
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
Old 10-13-2007, 12:43 AM   #3
syndr0me's Avatar
Trader Rating: 32 (100%+)
I believe Novak made a running change on the GTB and started including LiPo cutoff. I don't remember how to tell, though. If someone from Novak doesn't answer your question here, send an email to [email protected] and they should be able to lead you in the right direction.
syndr0me is offline   Reply With Quote
Old 10-13-2007, 12:46 AM   #4
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
I can tell you when i get home at 7am, i got this little peice of paper with mine for some reason that tells you how to, but mine does not have the lipo cutoff.
Ill scan it and post a pic of it.
ben
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 10-13-2007, 02:10 AM   #5
-KilleR-'s Avatar
Trader Rating: 15 (94%+)
From TeamNovak website:
The GTB Brushless/Brush ESC includes Built-in Li-Po Cut-Off Circuitry, which monitors the vehicle’s Lithium Polymer battery pack’s voltage, and prevents the batteries from going below the critical safety voltage level (6.25 volts).
-KilleR- is offline   Reply With Quote
Old 10-13-2007, 02:15 AM   #6
-KilleR-'s Avatar
ben
check this out.. http://www.teamnovak.com/download/in...Prog.Sheet.pdf
under to activate liPO cut-off circuitry
Old 10-13-2007, 05:39 AM   #7
1M
1M's Avatar
Trader Rating: 35 (100%+)
Must be the older GTB units didn't have the Lipo cut off. I checked the link showing it in the instructions, I checked both my instructions and its not listed.
1M is offline   Reply With Quote
Old 10-13-2007, 08:36 AM   #8
Hopefully Novak can answer this. I have two of the older (non-lipo) GTBs. Can they be upgraded to the new circuitry if sent in and what would be the cost?
Thanks, Pete
Pete Thomas is offline   Reply With Quote
Old 10-13-2007, 09:16 AM   #9
STLNLST's Avatar
Trader Rating: 21 (100%+)
The newer GTB that says "spread spektrum" has the lipo cut off. If you have one of the first generation/older GTB's it won't have the lipo cut off. Lipo's weren't thought about when the GTB was first released and now that they have come to light Novak has upgraded their speedo to better handle the newer technology. The only thing the new speedo can't do is stop your current IB packs from self discharging.... (lil joke there) I hope this answers your question and if you need any other Novak related info go to the "ask steve" thread on here. He a Charlie are always answering questions.
STLNLST is offline   Reply With Quote
Old 10-14-2007, 03:41 AM   #10
-KilleR-'s Avatar
Yes only newer GTB have built-in lipo cut-off. Just get mine a month ago.
Old 10-14-2007, 06:54 AM   #11
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Thanks, Pete
You can send in any GTB and exchange it for any other GTB for $69.
http://teamnovak.com/cs/web_options/index.html
[G] GTB DIFFERENT MODEL EXCHANGE PROGRAM: Customers returning a GTB ESC (#1710, #1710-L, #1711, #1714, & 1715) for non-warranty service can request to replace their unit with a different Factory-Remanufactured GTB model for a $69 exchange price. Indicate model and Service Code (G) on Non-Warranty Service Form.
Turbo Joe is offline   Reply With Quote
Old 10-14-2007, 07:30 PM   #12
diha's Avatar
Deleted.......
diha is offline   Reply With Quote
Old 10-14-2007, 07:40 PM   #13
magm20001's Avatar
to see if your one has lipo cut off, hold the button down, till the amber/red light shows.
1 flash = cut off disables (OFF)
2 flashes = cut off enabled (ON)
its in the novak instruction sheet
if you got lipo cutoff enabled, the red/yellow led will blink 3 times, at startup
anyway, ALL the SPREAD SPEKTRUM GTB's have lipo cut off circuitry.
Only the NEWER GTB (that are non spread spectrum) have lipo cut off.
so you have to check with your hobby shop if there is a sticker on the box indicating Lipo cut off circuitry.
RIP Kanye West ..... Mom
magm20001 is offline   Reply With Quote
Old 10-14-2007, 07:44 PM   #14
magm20001's Avatar
Originally Posted by diha View Post
Can I use the "spread spektrum" GTB with normal crystal transmittion?
I wanna buy a GTB but my LHS only have the "spread spektrum" GTB and not the normal GTB. Any issues??? My receiver is KO KR302.
no you can not.
Old 10-14-2007, 08:45 PM   #15
Trader Rating: 28 (100%+)
Since this is a gtb thread I have some motor questions..
I have a 7.5 and 6.5 older smooth can brushless novaks. No sintered rotors. Can I just pick up any sintered rotor and it will work in my motors? And do the newer motors have a bigger bearing or something than the older motors?
jbrow1 is offline   Reply With Quote
NIB GTB W/ Lipo Cutoff kartermdb R/C Items: For Sale/Trade 0 07-31-2008 03:08 PM
Novak GTB with lipo cutoff HVAC25000 R/C Items: Wanted to Buy 4 07-14-2008 06:39 PM
Looking for GTB w/LiPo cutoff Scottrik R/C Items: Wanted to Buy 3 04-16-2008 06:54 AM
GTB w/ lipo cutoff convikt R/C Items: For Sale/Trade 0 02-17-2008 11:04 PM
Lipo Cutoff Module compression911 Singapore R/C Racers 2 01-08-2008 04:30 PM
