Old 10-11-2007, 03:08 AM   #1
Default Rc body drilling help
hey guys i have a bought a new shell for my car and it is pre painted so how do i go about drilling holes in the correct places for the body clips?? does anybody have any tips?
thanks!
quickzx is offline   Reply With Quote
Old 10-11-2007, 03:42 AM   #2
JRXS_chris's Avatar
Just dab some diff grease onto the top of the body post, pop the body over the chassis in the correct place and ream/drill where the grease has stuck to the body.
JRXS_chris is offline   Reply With Quote
Old 10-11-2007, 03:43 AM   #3
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
I hear that these are pretty nice to have:
http://www2.towerhobbies.com/cgi-bin...?&I=LXFZW1&P=7
But I know others that shine a really bright light up from underneath the chassis to locate where the body posts contact the body.
I just do it Stevie Wonder style and with firm pressure, try to feel where the posts are located. Some day, I might remember to mark the holes before I paint the body.
K_B is offline   Reply With Quote
Old 10-11-2007, 04:10 AM   #4
rampal's Avatar
Send a message via MSN to rampal
toothpaste. Put some over the body posts, locate the body and press.... better and cheaper than anything (unless you don't brush your teeth )
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 10-11-2007, 04:13 AM   #5
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
If someone has teh same car, and same bumper setup as you take off their wing and copy the holes
ott light trick works good for white or a bright body...
I have also used a paper hold puncher and puched out 4 holes in a 2 way tape strip and put them on the tops of the boddy post..
Using a dark diff grease works to, then you can measure a point of reference to make sure the holes are pefect
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 10-11-2007, 05:03 AM   #6
joe of loath's Avatar
anything that goes on the body post and marks the body will work. diff grease, toothpaste, blood...
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-11-2007, 06:49 AM   #7
timmay70's Avatar
Chop out the top of an old shell (same make) that was mounted properly and transfer the centers of the holes from there. Keep this template for all future shells of the same make.
Check your front bumper/body mounts, too. If they are 'race hardened', it's probably time to replace them. This way the template will always work.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-11-2007, 08:10 AM   #8
Trader Rating: 38 (100%+)
Just keep punching holes into it until its good enough then cut your wheel wells really large. That what I see done most often
or8ital is offline   Reply With Quote
Old 10-11-2007, 09:13 AM   #9
macnkitty2002's Avatar
i often have the issue of mounting my body too snugly on the chassis, talk about wheel rub.
Team Associated RC10B4.2
Losi Rock Rey
macnkitty2002 is offline   Reply With Quote
Old 10-11-2007, 10:13 AM   #10
scootr117's Avatar
"He ain't lyin' "....
scootr117 is offline   Reply With Quote
Old 10-11-2007, 06:53 PM   #11
lol i know a guy from my lhs that put his hole in the shell with an air rifle hope his aim was good.
i used some dif grease and a knife to put mine in not the neatest of body mount holes but it worked.
khubner is offline   Reply With Quote
Old 10-11-2007, 07:01 PM   #12
Trinity has no brainier body post markers. Thats what I use and they work great!
Corally USA - Specialized R/C - eXpress Motorsports - MW Designs - rD2
xxx787 is offline   Reply With Quote
Old 10-11-2007, 07:04 PM   #13
Like post #3 says?
Old 10-11-2007, 07:26 PM   #14
Like post #3 says?
Good Call... Capitan Obvious hear..
Old 10-12-2007, 01:26 AM   #15
acko's Avatar
before i paint the shell i sit it on my chassis. making sure my wheel arches are in the right spot, making sure ive got the same clearance on each side. then with a permiant marker put a dot in the middle off the post on the shell. paint it etc....drill it or rheem it, peel the protective film off and there ya have it. the only 1s ive stuffed up are when i forget to mark it before i paint
hope this isnt to complex for ya to try. i dont like grease as paint doesnt like to stick to the residue and i dont like makin extra work of having to clean before paint
TEAM TRASH TALK TOURING
losi mini baja/ sidewinder brushless on 3s li-po
losi xxxt mf2/ speed passion brushless 4.5 + li-po
pti goliath crawler... (always being modified)
hpi baja 5b ss 29.5 cc setting up 4 1/4 scale speedway
acko is offline   Reply With Quote
Drilling Carbon Fiber Chassis 190mph Electric On-Road 15 02-01-2008 09:52 AM
Drilling holes in brushes Phroz Electric On-Road 5 06-24-2007 07:14 PM
drilling rims schmuck Rookie Zone 6 12-28-2005 11:32 PM
Drilling holes in brushes Sal Amato Electric On-Road 15 10-25-2004 07:56 AM
Brush Jig - hole drilling Jammin J R/C Items: Wanted to Buy 0 04-17-2004 08:49 PM
