Old 05-19-2003, 08:17 PM   #1
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
Default Accidently cut antenna (Solder???)
just today i was trying to fix my car from glitching so i cut the wire strap that was holding my antenna down to the carbon fiber chassis of my 414mii
then i cut the stupid antenna
i soldered it back
was this the right thing to do?
Calvin Ng is offline   Reply With Quote
Old 05-19-2003, 09:21 PM   #2
JohnA's Avatar
It should be fine as long as you insulate it where you soldered it.
JohnA is offline   Reply With Quote
Old 05-19-2003, 09:21 PM   #3
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
if it is a novak fm, go to radio shack and get 18" of 26 gauge standed wire.....
Matt M. is offline   Reply With Quote
Old 05-19-2003, 09:24 PM   #4
mushu's Avatar
Don't worry. As long as you didn't significantly change the length of the antennae wire it should be just fine. Conductivity isn't that critical and a proper solder joint won't product enough resistance to cause glitching.
mushu is offline   Reply With Quote
Old 05-19-2003, 10:04 PM   #5
Default Re: Accidently cut antenna (Solder???)
i soldered it back
If the wire was next to the carbon fiber chassis, this could be your cause for glitching. Try using some rubber fuel tubing or electrical tape where the wire runs along the chassis.
-H
Headbanger is offline   Reply With Quote
Old 05-20-2003, 05:53 AM   #6
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
I would resolder a new antenna on. If you cut it, than you'll have to splice and depending on how good your soldering skills are than you could change it by 10mm or 10% of the length and that can affect your range/glitching. Antenna wire is only about 1.50 at your LHS.
John Fontaine is offline   Reply With Quote
Old 05-20-2003, 06:36 AM   #7
yobbism's Avatar
Yeah I'd redo the wire from the board of you receiver. I did to mine, and its another way to colour code your car! so you would be better off getting some nice looking blue wire. If you dont want to touch the board just take it to a meeting and a heap of people should be able to help!
BTW I lengthen and shorten my AM antena wire all the time with no effect, as long as it is still going up in a tube. Is this not the case with FM?
yobbism is offline   Reply With Quote
Old 05-20-2003, 10:56 AM   #8
CGR
CGR's Avatar
My antenna got ripped out of my reciever (airtronics) in a marshall incident the other day. Got a length of JR antenna wire ($1.50) form the LHS cut it to the same length, opened the case and soldered on the new one. No probs so far.
CGR is offline   Reply With Quote
Accidently put air filter oil in my nitro engine snowdins Nitro Off-Road 9 05-14-2008 07:27 PM
Solder / Solder Stand - Available Online? RC12 Electric On-Road 7 05-01-2008 10:20 AM
how can i get all the solder off my esc? losithrasher Electric On-Road 12 12-18-2007 09:15 AM
M8 antenna and Solder Stevietd14 R/C Items: Wanted to Buy 6 05-06-2006 03:03 AM
Solder TC3 Electric On-Road 13 02-08-2003 09:44 PM
