Old 10-09-2007, 12:58 PM   #1
Default once again a motor upgrade ?
i just finally soldered my epic intense 8turn double motor onto my tc4 using the stock spur 72tooth 48pitch. i suck with gearing so i need your help. wich pinion should i use. the manual for the car only goes to a 10turn double and sais a 21 pinion using stock spur.
i have an 18tooth would that work.
RoseTuned is offline   Reply With Quote
Old 10-09-2007, 06:40 PM   #2
60 views and no help . help if you can plz
Old 10-09-2007, 07:03 PM   #3
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Rubber tires or Foam.?
Indoors or out doors.?
I would start with a 16 or 17 indoors.
18 or 19 out doors.
(Rubber tires)
UN4RACING is offline   Reply With Quote
Old 10-09-2007, 09:57 PM   #4
i do not race, this is for my own personal speed and fun. i am running rubber tires on asphault outdoors.
right now its at 72/18. i am using my epic intense 10x2 modded into a 8turn double. it does seem to get hot running an 18t pinion was thinking maybe a 17 but i like the speed of the 18.
whats the differnece between rubber and foam?? is foam faster or rubber or opposit?
i have my rear diffs open but alittle tight and i am running a front one way if u need that info.
Old 10-09-2007, 10:36 PM   #5
UN4RACING's Avatar
If its hot it could be a lot of things as long as it doesn't get to hot it should be ok.
The 17 sounds to be the better though. The foams wont be better if just racing around the street I would stick to the rubbers. I would get some treaded tires.
The car will probably handle better if you loosen the rear diff a little.
Old 10-09-2007, 10:45 PM   #6
yeah i am going to loosen the rear. i just baught some black and stealth team associate lube and grease. i dont want to loose any speed wich sucks cause if i go lower i loose.
i need to find a way to make it faster maybe get a 6turn double motor. im not sure yet.
Old 10-10-2007, 05:52 AM   #7
If you want more speed, go brushless. you'll have more speed than you know what to do with.
parnelli97 is offline   Reply With Quote
Wanted Upgrade Motor For My KMI fastmax R/C Items: Wanted to Buy 1 08-25-2008 04:23 PM
???MICRO RS4,WHAT UPGRADE MOTOR & ESC??? xsxracing Micro and Mini Scales 5 10-13-2007 02:26 AM
Motor Upgrade Sweeney921 Rookie Zone 8 01-30-2007 07:37 PM
Motor upgrade e-g33k Rookie Zone 13 11-30-2005 12:31 AM
XXX-S Motor Upgrade Losifreak Electric On-Road 1 08-22-2004 11:13 PM
