Old 05-20-2003, 02:45 AM   #16
davioh's Avatar
im still leaning towards the futaba's but what are the differences of 600c and 800c?
davioh is offline   Reply With Quote
Old 05-20-2003, 03:12 AM   #17
davioh's Avatar
i hav one question...how come the MC800 has 3 wires and the MC600 has 4? shouldn't it have 4?
Old 05-20-2003, 03:13 AM   #18
davioh's Avatar
Old 05-20-2003, 03:39 AM   #19
TWiZTiD's Avatar
i would go for the gm v12 its never misses a beat i had a dominater and it smoked the first time outta the box and now i have gone back too the GM V12
TWiZTiD is offline   Reply With Quote
Old 05-20-2003, 08:09 AM   #20
fatdoggy's Avatar
R/C Tech Charter Subscriber
davioh - No you can have 3 or 4 wires come from esc's. 3 wires means that you will have to do some soldering because the red wire goes to both the positive battery and the positive motor terminals. If your ok with soldering and just want a high quality racing esc then go with the MC800C over the MC600C.
fatdoggy is offline   Reply With Quote
Old 05-21-2003, 02:50 AM   #21
davioh's Avatar
what so "high quality racing" with the 800c? is it cuz it goes to 5 turns? cuz i run 23 stock and 11T mod and i was wondering why would the 800c be better than the 600c other than the turns number
Old 05-21-2003, 03:29 AM   #22
fatdoggy's Avatar
Here are the specs of each.
"MC800C"
TECH NOTES
This is a MC800C Electronic Speed Control for 5+ Turn Motors.
FEATURES: Operates motors that are 5 turns up.
SMD Mosfets with smallest internal resistance for minimal losses
and maximum power.
Digital variable modes "Power Control", "Hyper Brake", and
"Neutral Brake".
Optimum 3140 Hz digital High Frequency
Start Acceleration Function
4-Cell Operation possible without receiver battery.
External solder points for the motor and battery leads.
One Year Warranty
INCLUDES: One MC800C Electronic Speed Control w/ Reverse and Brake/ Futaba J
receiver connector, and On-Off Switch.
One Plastic Adjustment Screwdriver
Three Motor Capacitors
One Schottky Diode
Four Black zip straps
Double Sided Tape
Instructions
REQUIRES: Futaba J compatible receiver.
Female bullet motor connectors for motor, use TRIC5500.
Battery Connectors
SPECS: Capacity: 4 to 7 cell batteries
Motor Limit: 5+ turns
High Frequency: Yes, 3.1kHz
Connectors: Futaba J
Bullet Motor Wire: 12 gauge
BEC: Yes
Length: 1.11"
Width: 0.57"
Height: 1.00"
Weight: .62 oz
"MC600C"
TECH NOTES
This is the MC600C Forward/Brake Sport Speed Control by Futaba.
This will handle 10 Turns and above.
++ Additional Technical Information Will Be Added As It Becomes Available. ++
FEATURES: All connectors and heatsink are pre-installed.
Has Software Protection against: Heat, Current Overload, Short
Circuits, (It is NOT protected against reverse Polarity).
Easy Push Button Set-up.
Forward and Brake only.
Can handle 4 to 8 cells.
Will handle motors of 10 Turns and above.
INCLUDES: One MC600C Sport Speed control,
Mini Screwdriver
Capacitors
Schottky Diode
Double sided tap
REQUIRES: Receiver that accepts Futaba J connectors.
SPECS: Dimensions: 1.0"x.91"x.63" (25.4mmx23.1mmx16mm)
Weight: .53oz (15g)
Freq: 2.5kHz (2500Hz)
BEC Voltage: 5.0
Wire: 14 Gauge
The 800C has alot more setup features, cand handle fewer turns and has a lower internal resistance. Both are good esc's so if your not a serious racer and your not going to use the features then there's no reason to spend more for the features. By the way, why not just send the esc you have in to be repaired?
Old 05-21-2003, 03:46 AM   #23
davioh's Avatar
send to where? i'll see what to get once i get to the shops...i'll see waht the shop guy recommends
Old 05-21-2003, 03:47 AM   #24
davioh's Avatar
oh and will the heat sink of the MC600c work on the mc800?
Old 05-21-2003, 08:19 AM   #25
fatdoggy's Avatar
Go to your LHS and they should be able to hook you up with the distributer in HK.
Old 05-21-2003, 08:21 AM   #26
davioh's Avatar
whats my LHS?
Old 05-21-2003, 08:23 AM   #27
fatdoggy's Avatar
Local Hobby Shop.
Old 05-21-2003, 08:42 AM   #28
DaveW's Avatar
The lack of a fourth wire decreases resistance and voltage drop for more efficiency. Most four wire speedos have the red fourth wire right next to and soldered to the other red wire on the PC board. The less resistance = more power and runtime. In most cases, you get what you pay for in electronics. The LRP Quantum Comp (or its Futaba equivalent), the Keyence, and the Novak GT7 are the top of the list in this dept. There are some durability issues on the GT7. The warranty is best on the LRP as stated above. Depends on if you wanna spend 200$ once... or twice i guess.
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 05-21-2003, 09:23 AM   #29
davioh's Avatar
Originally posted by fatdoggy
Local Hobby Shop.
hehe...alright...there are about 20 of them hk and im not sure which one i got the ESC in...but depending on the price, i am going for the 800c.
Old 05-26-2003, 03:52 PM   #30
GTMilenko's Avatar
you lucky bastard! i have 1 hobby shop and it is useless, never have anything i need, have to order everything, usaully a 4 week wait for any part and everything costs about 3times as much as in hong kong.
i just order from rainbow ten now.
wanna swap contries?
with the prices here its no surprize i seem to be the only one it town with a rc car
GTMilenko is offline   Reply With Quote
