Old 10-18-2007, 12:06 AM   #46
Im refering to the chart posted by nikkiesteban it illustrate their the red marker on "D" for 25/55 motor.
Im wondering what that represent.
best of blue is offline   Reply With Quote
Old 10-18-2007, 12:15 AM   #47
doh. yeah looks like 'a' to me, as pointed out by greasemoneky.
slomo is offline   Reply With Quote
Old 10-18-2007, 02:08 AM   #48
you are right its "a" my bad
Old 10-18-2007, 02:50 AM   #49
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
its just a pattern color coding. so that we wont make mistakes in screwing the motor in. the red doesn't represent anything like STOP or DON'T but it says that if you will screw it in red dot on the other side the other screw should be in the other red dot also. also same with the blue, yellow,others, gt it?
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 10-30-2007, 06:23 AM   #50
Default tt-01 issue
Hi i bought a stock tt-01 just the other day got it all together but when i reverse or once the battery starts to die down it jerks and doesnt go anywhere unless i slowly give it acceleration but i still cant go flat out does any one know how to fix this problem or better yet tell me what could be causing this thank you.
matt_666_xpor is offline   Reply With Quote
Old 10-30-2007, 07:16 AM   #51
it's normal.. the stock ESC(teu-101bk) has a certain voltage cut-off.. its normal.
don't discharge your battery by running in the car. you may damage the battery.
some batteries tends to die/deteriorate when the voltage goes below 5.4volts for the whole pack(6 cells) / 0.9 (each cells).
Old 10-30-2007, 12:21 PM   #52
dfiantii's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to dfiantii Send a message via Yahoo to dfiantii
Thumbs up
best of blueI had the same problem i changed my propeller joints and ordered an aluminum shaft and it was to small. When you change the joints you have to upgrade the aluminum shaft to a different model one.You have to get the (TB Evo IV) aluminum shaft and it takes up most of the play you may still have to use and o-ring but it won't be as bad as the play you have now. I guess Tamiya forget to let us know when you upgrad the joints you need a longer shaft than the one they have.
dfiantii is offline   Reply With Quote
Old 10-31-2007, 02:40 AM   #53
ok thank you and also do u know if im able to run a 3000mah battery.
Old 10-31-2007, 02:49 AM   #54
yes you can i am running 3000's now i beleive you can use any mah rateing you want so long as the voltage is not greater than 7.2V
khubner is offline   Reply With Quote
CX2 Issues 140ce RC Flight 4 01-21-2008 12:12 AM
Some issues with the Lst sjlam Monster Trucks 7 11-06-2005 06:50 AM
help my 3 pk has issues papadocks R/C Tech Site Forum 6 04-26-2005 08:34 PM
FTS issues TeamButter Florida Racing 30 02-24-2005 06:01 PM
Issues with Tamiya TRF 415 - Please note rcmaster.net.au Australian Racing 47 04-14-2004 02:55 PM
