Old 10-16-2007, 12:26 AM   #31
Originally Posted by best of blue View Post
Hi to all,
I bought a "aluminum center shaft" and "aluminum center shaft cap" for tt-01. when i tried to install it i notice that the center shaft is too small,
Whats the reason of it? I followed the step by step procedure but the center shaft have tendency to move out to the cap.
Did I bought the wrong parts?
But its indicate its fot tt-01. Any sugestion
This is the only place i can ask a question.
Thank you and hoping for your reply.
Can someone advice me on what should I do to resolve this problem? Any suggestion would be highly appreciated
best of blue is offline   Reply With Quote
Old 10-16-2007, 12:33 AM   #32
nikkiesteban's Avatar
Send a message via Yahoo to nikkiesteban
Hi to all,
try to put o-rings inside the cap and see if its moving and add until it has only a small amount of play.
hello miss, puwede pa bind?
nikkiesteban is offline   Reply With Quote
Old 10-16-2007, 01:05 AM   #33
Hi nikkiesteban,
thanks for a quick reply, I got the idea but, what is o-rings is that included in the package of tt-01,
or can I replace o-rings with plastic coming from the exta parts of tt-01?
sorry for asking such a stupid question, but I realy dont have an idea, thanks!
Old 10-16-2007, 02:03 AM   #34
Hi nikkiesteban,
you can also buy some o-rings at the nearest hobby shop.
don't try the plastic as a spacer because it might scrape your aluminum center shaft and it might chatter. it will be better if you can find rubber o-rings.
this is what o-rings look like
Old 10-16-2007, 06:37 AM   #35
Oh I see, similar to the rubber I put in my damper,
Iam 1 hair away from quiting this hobby by to much prostration
Thanks there is always some one like you willing to share knowledge up to the extents!
Thanks again!
Old 10-16-2007, 07:13 AM   #36
Originally Posted by nikkiesteban View Post
if you have above 25t pinion and if u want to use a higher gear ratio you can fit it in oringal enclosed gearbox but you have to use 52t spur gear of f201.
ok i'vr found me a f201 high speed gear set looks as if it comes with both a pinion and a spur now your 100% sure these will fit my tt01
khubner is offline   Reply With Quote
Old 10-16-2007, 07:15 AM   #37
i haven't tried it. but look in the picture attached. see the gearings.
Old 10-16-2007, 08:23 AM   #38
Default hmm
Originally Posted by AussieSamurai View Post
This thread can be for anyone who is having trouble with their TT-01. (Like me)
My TT-01 goes haywire whenever it gets either to a certain distance away from me or goes too fast or is just completely random. (not sure which but i think its the too far away one) By haywire I mean I have absolutely no control over it for about 2 secs but in this time it accelerates to full speed and does random turns usually resulting in a massive stack. I have changed my transmitter and receiver and crystals and batteries (in car and transmitter) and that has not worked. What is the problem? Please help going racing soon.
i have had this same problem as u. however, this problem happened on my ta05. its not ur transmitter but ur motor. ur sport tuned might have been too used. get a new motor. (it doesnt cost much for a sports tuned). after gtting a new motor, if this still happens, its ur esc. cause u have already change ur tx and rx already.
hottapole is offline   Reply With Quote
Old 10-16-2007, 12:13 PM   #39
wog....supraman's Avatar
Send a message via MSN to wog....supraman
i have never had probs with intereference with my TB02 setup...i have my antenna wire running parallel with the motor (.5cm clearance on the motor) for the whole length of the motor....no caps and the rx is rite next 2 the mtor...and no probs
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 10-17-2007, 08:18 AM   #40
double post
Old 10-17-2007, 08:22 AM   #41
me confused whats the significance of the red dot marker on the motor holder if i will use 25/55?
or what should i do to that red dot marker?
thanks!
Old 10-17-2007, 09:48 AM   #42
wrong post!
Old 10-17-2007, 10:58 PM   #43
thanks!
do i have to screw the motor to red mark if im using 55/25?
Old 10-17-2007, 11:02 PM   #44
GreaseMonkey's Avatar
Looks to me like you would use the blue holes if you are running a 25t pinion and a 55 tooth spur. At least going from the picture supplied.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 10-17-2007, 11:05 PM   #45
I dont know of the red dot you are referring to. Download the tt01d or r manual from tamiya. There is a gear chart with motor positions.
slomo is offline   Reply With Quote
CX2 Issues 140ce RC Flight 4 01-21-2008 12:12 AM
Some issues with the Lst sjlam Monster Trucks 7 11-06-2005 06:50 AM
help my 3 pk has issues papadocks R/C Tech Site Forum 6 04-26-2005 08:34 PM
FTS issues TeamButter Florida Racing 30 02-24-2005 06:01 PM
Issues with Tamiya TRF 415 - Please note rcmaster.net.au Australian Racing 47 04-14-2004 02:55 PM
