Old 10-03-2007, 11:35 AM   #1
sheetmetal2's Avatar
Default Tire Truer
I am looking for a tire truer. We only run sedan. I have looked at the manual truers and think that for the money that would be the way to go. Am I missing something? Other then the obvious advantage of the automatic truer what else is there? Any help/information is greatly appreciated.
www.rcxracing.com
Rc10 Gt EDM
M&M Racing Klien Sprint Car
Losi Mini T
sheetmetal2 is offline   Reply With Quote
Old 10-03-2007, 12:09 PM   #2
Trader Rating: 32 (100%+)
Send a message via AIM to A. Rhodes
If you can afford it, the Hudy truer is by far the best truer on the market. The bit alone is worth it's weight in gold; perfect, clean cuts every time.
http://www.hudy.net/xhudy/products/p...7&kategoria=62
A manual truer will work, just make sure you get one with a good bit, or that a Hudy bit will work in. The main benefit of a automatic truer over manual is that it is automatic; turn it on and it does all the work for you, freeing up some time to relax or talk with your friends while at the track.
Retired from RC....
Quantum - St. Croix - Bass Pro Shops - XPS - Rapala
A. Rhodes is offline   Reply With Quote
Old 10-03-2007, 01:01 PM   #3
SlamMan's Avatar
What he said.
Michael H
OnRoadColorado.com
Colorado On Road RC Club
SlamMan is offline   Reply With Quote
Old 10-03-2007, 05:28 PM   #4
I don't think you can go wrong with a Hudy truer. I would pick up the carbide cutter at the same time.
chuck
mackin is offline   Reply With Quote
Old 10-03-2007, 05:37 PM   #5
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
The Hudy is pretty (and $$$)...but their bit/blade will also fit on just about any cutter and it'll cut just as nice.
Turbo Joe is offline   Reply With Quote
Old 10-03-2007, 06:54 PM   #6
wallyedmonds's Avatar
hudy is best if you want to spend the $.
it will do you well and if there is 2 or more ppl using it you'll be happy.
wallyedmonds is offline   Reply With Quote
Old 10-08-2007, 12:14 PM   #7
Default truer
I understand the benifits to the automatic part of the truer. We only race on a club level with a couple extra races thrown in. I think last year we went through maybe 4 sets of tires. Is this worth the extra expense of the auto truer? Has anyone had a manual and traded up? Was the step up worth it? Does the manual do a good job? Would I need to buy a new bit for a manual truer to make it work well enough?
www.rcxracing.com
Rc10 Gt EDM
Losi Mini T
Old 10-08-2007, 12:25 PM   #8
RC MARKET's Avatar
Foam tire or Rubber tire ?
if Foam tire can choice HUDY or 3 racing cheaper
If Rubber can choice Much More
RC MARKET is offline   Reply With Quote
Old 10-08-2007, 12:30 PM   #9
timmay70's Avatar
I use the Integy Eagle Racing Truecut #C22306 with a Hudy carbide bit. I had to grind the mounting tab thinner with a dremel to fit the truer's tool holder, but it cuts every bit as good as a Hudy truer. It's just a light weight manual portable you won't mind taking with you, which suits me fine. You will still need to purchase an arbor, but you would with any other truer, too. The lathe comes with a couple of cutters that will last quite a while, just when it's time to get more cutters, don't hesitate to get the hudy carbide, it will be the last you ever get. It will take all the standard sized arbors, too.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 10-08-2007, 12:33 PM   #10
Trader Rating: 27 (100%+)
Its not the fact that its automatic, it is extremly well made. As for the answer to your actual question, yes the manual will work just fine. Some times the dial "walks" on older ones so it may be a little different thean the next, but it is so minimal
convikt is offline   Reply With Quote
Old 10-08-2007, 01:59 PM   #11
James35's Avatar
I too have the Eagle Racing Truecut #C22306 and love it! The motor is quiet, yet it's a monster! There is no motor shaft slop, and it works well if you don't mind doing it manually.
It appears that Integy has bought out Eagle Racing's design, as it's now rebadged under the Integy name.
James35 is offline   Reply With Quote
Old 10-08-2007, 02:33 PM   #12
RaceAce701's Avatar
Trader Rating: 86 (99%+)
I also have one and love it the action is smooth and the motor has enought power to hack a tire to size in one shot
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 10-08-2007, 04:37 PM   #13
Thistle's Avatar
Send a message via MSN to Thistle
The only comment I'll make is:
Make sure the cut-depth guage is easy to read. I bought a Corally automatic truer, and use a Hudy carbide bit. It cuts great, but the guage is hard to read. It is printed on the actual slide barrel, and is in 2.5mm increments.
The guage on the Hudy is much easier to read, and is very accurate.
I've seen the 3racing truer, and it looks good. The guage is also easy to read, but I have no experiance with it's accuracy.
Thistle is offline   Reply With Quote
Old 10-08-2007, 06:20 PM   #14
Chemical X's Avatar
Trader Rating: 16 (100%+)
The Hudy is definitely an excellent truer, but if you're only going to use it a few times per year, look into the manual truer from Ofna, PN 20002. These can be found for ~ $60 USD. You'll still need an arbor though.
http://www.ofna.com/tool-Tire.html
Chemical X is offline   Reply With Quote
Old 10-08-2007, 07:02 PM   #15
haagar's Avatar
I have a 3 racing truer, but put a Windtunnel cutter on it. Overall it works great. The only issue is that with the Windtunnel bit I couldn't cut 1/12 tires once it got small, so I extended the bit out. The markings were pretty accurate with the hacksaw blades (within a mm) and after figuring out the difference with the new cutter can get my tires pretty much right on the first try.
haagar is offline   Reply With Quote
MaxMod Tire Truer (large AC version w/adjustment for cutting camber into the tire) Danny-The-Dude R/C Items: For Sale/Trade 3 02-26-2007 03:10 PM
llooking for a hudy tire truer or an auto truer hpiaustin R/C Items: Wanted to Buy 2 12-09-2005 06:56 AM
Questions on Tire Truing and the Eagle Racing Tire Truer nitro_tacklebox Electric On-Road 5 04-21-2005 03:39 PM
Integy Tire truer, Arbors 1/10 and 1/12 plus carbide tire file evostyle R/C Items: For Sale/Trade 11 03-22-2005 11:58 PM
WTB Hudy Tire Truer Automatic or Other Tire Truer 993power R/C Items: Wanted to Buy 0 10-23-2003 05:47 PM
