Old 10-02-2007, 09:50 PM   #46
Stagger2's Avatar
Originally Posted by tbeardmore View Post
HOW ABOUT SOFTER WALLS... LIKE NASCAR?
Matt, Todd is looking out for us............that is when he puts US in the wall.
Chad O
Hobbytown Hobbyplex, Customworks Aggressor 17.5 Truck, Brushless and Lipo all the way
Staggered F/X body painting
Stagger2 is offline   Reply With Quote
Old 10-02-2007, 10:09 PM   #47
tbeardmore's Avatar
Chad O
No... Chad! You've got it all wrong... It's all about safety, and creash survive-ability...
I was think about requiring the "Hans device" for all drivers.............. but then, that would be just plain silly - wouldn't it?
BMI DB10R, Corally RDX PHi, BMI 12R..!!
Need a "real" car... contact me at:
www.beardmorechevy.com -or- www.beardmoresubaru.com
tbeardmore is offline   Reply With Quote
Old 10-02-2007, 10:57 PM   #48
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by UN4RACING View Post
Pre liquid masked bodies. Then you could just cut out a design and paint it. I think that would be cool.
Hey, what the hell do you think you're doing in here with that perfectly good idea? Can't you see all the nonsense going on in here? DAMN!
But seriously, that's F'n genius right there!
Greg Sharpe is offline   Reply With Quote
Old 10-03-2007, 02:22 AM   #49
bxpitbull's Avatar
I wouldnt say "non-sense" for some, just impratical. But, at least people are thinking. As long as it generates thought, people arent becoming complacent. Mission accomplished.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 10-03-2007, 03:31 AM   #50
tc3team's Avatar
Even higher capacity cells, 4500s are common now, where will it stop???
Soon we will need the national grid just for r/c racing to charge them
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-03-2007, 03:42 AM   #51
tc3team's Avatar
ESC's are probably not going to get much better, the on resistance of the top of the range units we have now are just crazy as you get more resistance from the solder going to the wires.
Electronic disc brakes with carbon in them???? Who knows. I dont think there is much out there now that hasnt been seen already.
If its anything electronic, expect to see it in Japan first I would have thought.
Old 10-03-2007, 07:32 AM   #52
scrubnick's Avatar
Send a message via AIM to scrubnick
Kyosho ( I believe) had a gyro-type device for rc cars a long time ago. It could provide steering corrections while driving. I think Car Action did a review of it a long time ago. Of course, such items are strictly prohibited from racing, so it never took off.
scrubnick is offline   Reply With Quote
Old 10-03-2007, 07:47 AM   #53
bxpitbull's Avatar
I thought that to be true. How dare they come up with something that assists drivers, making things easier
Old 10-03-2007, 08:19 AM   #54
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Originally Posted by ckearns View Post
I would envision improved telemetry requiring some sort of assistance from the shop/track to make it really beneficial. Consider a 4-5 (4 for X/Y and 1 for Z positioning) antenna spread working like GPS satellites and a small data logger recording inputs from the radio and an on board gyro.
Add a small transmitter/receiver system, and you'd have positioning at .5 second or better intervals. In theory, you would be able to record and play back an entire race based on recorded data and see what parts of the track you could be running faster on.
Without the antenna spread but including the on board telemetry and gyro data, you would be able to produce a log of the inputs, but without some sort of track position it would be a bit of guesswork to determine where you really were.
But man, it would be cool!
Perhaps the next great improvement will be in dampers. Fluid filled with big bore shafts and a needle valve body/pressurized reservoir to adjust the damper rate rather than dumping out globs of silicone oil on the coffee table. Adjustability from 20w to 70w oil in 5w increments along with 10 or more 'piston' adjustments please.
Chris
The telemetry and data logging already exist and have for years....
www.eagletreesystems.com
www.nomadio.net
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 10-03-2007, 08:54 PM   #55
Slidewayz's Avatar
How about active ground effects/wing control like the Bugatti Veyron and some 911's have. Low drag down the straights but loads of wind assisted braking and downforce for the corners. Some slot cars had flexible winged bodies which put loads of downforce on the cars to the point where they could run upside down.
Tracks could run a magnetic rail gun/gauss gun arrangement under the track straights that could provide an external power launch to cars much like a steam catapult does to planes on an aircraft carrier. Drivers would get say 5 boosts in a race that they could use.... Or access to an overvoltage function, where an additional AAA sized cell could be used until depleated. It would make for more strategic racing...
As the battery power goes up, so do motor temps, so better cooling systems are going to be a big thing. TCS is already leading a novel approach to this charge. www.tcscooling.com LN2 systems to follow I'm sure
Tamiya TRF-415 MSX/X (540/GTX), Team Magic E4 (17.5/GTBss), Tamiya TA-04 TRF (3.5/GTB)
Tamiya M03 SWB (3000kV Brushless), JR-Z1 Spektrum & KO Servos. www.lcrccc.com
Slidewayz is offline   Reply With Quote
Old 10-04-2007, 12:01 AM   #56
bxpitbull's Avatar
I mentioned that in a previous post..unfortunately, ROAR shot that down so fast. Many racers aint for it either. I know of several folks that own the cooling system and they say there is a significant difference in temps with the system.
Whats better............ TimXLB Chat Lounge 15 10-15-2007 06:10 AM
whats better? [email protected] Nitro On-Road 3 08-03-2006 05:33 PM
whats better? [email protected] Electric Off-Road 1 08-03-2006 09:12 AM
Whats up with the Set-Up? ERDrumlineSnare R/C Tech Site Forum 2 12-27-2004 09:33 AM
Whats yours? bran713 Australian Racing 36 09-13-2003 02:22 PM
