Battery slot fitment
I've bought a Xray T2 '007. What recommended methods are you guys using to enlarge the battery slots? I'm looking for a Dremel method. I found a few last week, but when I search for them I'm having no luck. So I have searched!
Any help would be great.
I just use a file and keep filing at a 45 degree angle on both sides until the cell sits flat with the bottom of the chassis. I try to get the cells as low as possible so that it lowers the overall centre of gravity but not so low that the cells get ripped apart going along the track! Make sure you superglue all the edges once you're happy with the position of the cells within the slots. Cheers, Chris.
Rob, what grit did you buy? Also, where did you purchase yours?
emery cloth
I also sand a a 45-degree angle to do the battery slots. A dremel works, but you need to be more careful with it.
