Old 09-29-2007, 10:54 PM   #1
scarymonster's Avatar
Default Bearing maintenance
How do you pry the seals out of the bearings on a T2 007 like the manual ses to do? I cannot get these out without mangling the seal itself. Any tips??? Thanx!
scarymonster is offline   Reply With Quote
Old 09-30-2007, 02:53 PM   #2
Send a message via MSN to TurboT
Do the bearings have a very thin snap ring on the outer edge of the seal or are they just a press-in rubber seal?
If they have a snap ring (look really, really close! It's very thin!) use a hobby knife to get under the open end and work it out while holding your finger on it, so that it doesn't spring out and away. Then use your knife, again, to get at the edge of the seal.
If there's no snap ring, then just use your knife to get the edgeof the seal up and, very carefully, work the knife around, prying up the edge around the bearing as you go. You should be able to get them out without bending the seal.
Team Great Hobbies
Team Durango Canada
Exotek
TurboT is offline   Reply With Quote
Old 09-30-2007, 07:35 PM   #3
Regional Moderator
CarbonJoe's Avatar
If you don't feel like doing this, just pick up replacement bearings from Avid. For a buck a bearing, you can't beat them. Fast shipping, too. I use them in my T2007, and in my XB8EC and XT8.
http://www.avidrc.com/
CarbonJoe is online now   Reply With Quote
Old 10-01-2007, 06:08 AM   #4
MrUnlimited's Avatar
If they are rubbershielded remove the shields and metal shields don't have to be removed.
Put them in a can and fill it with thinner (the one you use for paint) and let it stay overnight.
The next morning you take them out and let them airdry for a hour. after that reinstall the rubbershields on one side and put a drop of special bearingoil into the bearings, spin them and put the other shields on the bearings.
U5 Formulaboat 1/8 hydroplane - MHZ138 AQUAMANIA - Axial Exo Terra - Tamiya Avante - LC Racing EMB1 - Atomic AMZ 4WD Touring car
MrUnlimited is offline   Reply With Quote
Old 10-01-2007, 06:44 AM   #5
Trader Rating: 16 (94%+)
Ok, wish I had known about AvidRC a month ago before I dropped money elsewhere for bearings.
kn7671 is offline   Reply With Quote
Old 10-01-2007, 06:48 AM   #6
Ok, can someone tell me the benefits or advantages or rubber sealed versus metal sealed bearings?
It seems metal would be more logical for durability, but rubber sealed can be serviced better by removing the seals.
Old 10-01-2007, 07:51 AM   #7
tc3team's Avatar
Associated used to include rubber sheilded bearings in the rtr tc3 kits, and metal in the team/ft kits. So my take is its more of a cost issue than a benefit/disadvantage thing.
Durability is the result/bonus for paying more.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 10-01-2007, 08:03 AM   #8
Trips's Avatar
Trader Rating: 16 (100%+)
Rubber sealed bearings are betteer at keeping dirt out (and lube in) but the penalty is a bit of friction from the rubber seal touching the races.
Metal shielded bearings run a bit more freely, but the shields can allow some very fine grit to get in the bearing...
The metal shielded bearings will perform a bit better, but will require more frequent cleaning and lubrication to retain their advantage.
MARSHAL!!
Trips is offline   Reply With Quote
Bearing maintenance scarymonster Northwest Racers 4 09-30-2007 09:32 PM
Bearing maintenance AMGRacer Nitro On-Road 15 07-30-2007 04:54 PM
Bearing Maintenance Mossie Australian Racing 38 07-13-2004 04:54 PM
Bearing Maintenance S15Racer Electric On-Road 3 05-01-2004 09:54 PM
Ball Bearing Maintenance: How do you go about it? Alvin Electric On-Road 16 12-26-2001 03:08 AM
