Old 01-01-2002, 12:16 PM   #61
fhubbard - What do you mix with the VHT. I plan to use it for the next racing season.
Modena AL is offline   Reply With Quote
Old 01-01-2002, 12:27 PM   #62
Fred Hubbard's Avatar
Modena AL - You mix it with gasoline. It really isn't used as a direct application to the tires of your car, but more so as a additive on the surface of the track. Also, this was when all that was being raced were direct drive cars (pan cars).
Fred Hubbard is offline   Reply With Quote
Old 01-01-2002, 12:34 PM   #63
Thanks.
Old 01-01-2002, 12:35 PM   #64
Send a message via AIM to BigAn
What would you use as additive
and what incerts for sorex 20s
BigAn is offline   Reply With Quote
Old 01-01-2002, 01:11 PM   #65
Send a message via AIM to ZER01
BigAn- What surface do you plan on running the tires on? Respond with a surface and I'll respond with what I would try.
ZER01 is offline   Reply With Quote
Old 01-01-2002, 01:37 PM   #66
Think its ozsite carpet grey in colour would you uses additive with them or warmers
Old 01-01-2002, 04:59 PM   #67
BigAn, on ozite I've been using Sorex 24's with HPI green inserts on front, Sorex 20's with HPI red inserts on rear. I coat the whole rear tire with TQ Purple, and the inside 1/3 of the front with TQ Purple. Alot of guys use HPI red inserts all the way around, but I've already got a little too much steering. I might try it anyways, on my next set.
JeffC is offline   Reply With Quote
Old 01-01-2002, 07:02 PM   #68
Mopar's Avatar
Modena Al - VHT bottle instructions say to mix with methanol alchohol. I don't think you would want to use gasoline because of the oily residue it might leave on the track surface. When I had my own track (Loki Raceway in El Cajon, CA), I always used the methanol, it evaporates almost as fast as you spray it so you don't have to close the track for spraying. Also, the methanol has a sweet odor that is easier on the nostrils. It is more flamable though.
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
Old 01-03-2002, 10:15 AM   #69
Has any one tried Orion/JB Foam inserts? What are your thoughts?
racerdave is offline   Reply With Quote
Old 01-03-2002, 02:06 PM   #70
Racerdave: I have tried the JB foams (blue) with the following results: I tried them because they were so light feeling in the package and a couple of racers were using them with decent things to say about them. Upon installation, one of the inner pieces of foam pulled apart and had to be glued to the wheel. No real problem other than nominal hassle. They otherwise mounted up fine and worked pretty well for about 20 or 25 minutes and then the foam started bunching inside the tire. While I do not dislike them and would use them again in a pinch, the hassle of the two pieces and the bunching problem will steer me to another type of foam if possible. I would be interested in knowing of others had similar experiences when they tried them. Happy New Year!!
623B is offline   Reply With Quote
Old 01-03-2002, 05:18 PM   #71
jb rock
Old 01-04-2002, 09:42 PM   #72
Send a message via Yahoo to Doug Gaut
623B, we have been using the JB's here in Kansas and Oklahoma with great results. We race on an indoor concrete track. You didnt say if you glued the inner ring to the wheel. If you didnt, I am sure that is where the bunching problem lies. Go to Team Orions website, they have instructions on how to build the inserts. They work great and are much lighter!
Doug Gaut is offline   Reply With Quote
Old 01-06-2002, 11:21 PM   #73
BigAn- I would try HPI's greens and blues for carpet. Also, you might want to try Sorex's new firm insert out if it ever hits the shelves. Hope this helps.
Old 01-07-2002, 01:37 AM   #74
Regional Moderator
mr4-malta's Avatar
any toughts
on hpi 27's with hpi yellow inserts running on bumpy asphault?
or on yokomo 19's with a schumacher blue insert (foam insert -medium) ....i know these tyres work good just want to know what you guys think
mr4-malta is offline   Reply With Quote
Old 01-08-2002, 01:57 AM   #75
Default inserts for PitShimizu narrow D20s
Which inserts should I run in my narrow PitShimizu D20s? I use them on Tarmac that is quite often damp or wet. I run a XXXs with blue springs all round. Any help appreciated
chownr is offline   Reply With Quote
1/10 Offroad Tire and Insert Thread racenut123 Electric Off-Road 40 09-24-2008 09:14 PM
** Tire - Insert - Wheel SALE!! ** -NIP- NEW & used c1 racin R/C Items: For Sale/Trade 20 06-29-2007 07:39 AM
Tamiya Tire / Insert / Wheels (NIP) tamiyatrf R/C Items: For Sale/Trade 0 01-02-2006 01:54 PM
What Tire & Insert Combination For Hot Asphalt FREAKAH Electric On-Road 22 08-26-2003 10:28 AM
MoMo Tire Insert.................. Barry White Electric On-Road 0 03-18-2003 05:51 PM
