Old 12-12-2001, 01:38 PM   #31
I only use proline rims too. I'll never use another sorex rim....for some god awful reason, they kept backing out the wheels nuts and while I was leading the A-main, 2 wheels fell off.....
Modena AL is offline   Reply With Quote
Old 12-12-2001, 09:10 PM   #32
Trader Rating: 49 (100%+)
In reading through the posts on this topic, it would be helpful if you guys could put what you think is cold weather, hot weather, etc.
For Instance, my take on temps is this (this is obviously outside racing):
Cold Weather --> outside temp < 45 degrees
cool weather --> outside temp < 70 degrees
warm weather --> outside temp < 90 degrees
hot weather --> outside temp > 90 degrees
** Snowbirds ** --> let's hear some tire/insert combos for this race coming up in Feburary.
rodneybarrett is offline   Reply With Quote
Old 12-12-2001, 09:23 PM   #33
Send a message via AIM to ZER01
RodneyB- sounds like you hit the nail on the head with those tempertures. I agree. Although I would say the cold weather would be equilavant to <40*. Just Kidding that sounds good.
ZER01 is offline   Reply With Quote
Old 12-13-2001, 12:41 AM   #34
Jack_L's Avatar
haha, I said the opposite.
I'll never buy another Proline rim, b/c they warp themselves!
I am currently using the Sorex rims, and having good luck with them so far.
Jack_L is offline   Reply With Quote
Old 12-13-2001, 12:56 AM   #35
I've been using the sorex and haven't had any problems with them. Now I have seen the whole hex hub break out of the sorex dish but they seem to hold up for me. I agree with you Jack_L, the pro-lines seem a little soft where they will warp which will create runout. Not only that they don't make a 24mm dish wheel. I came across Speedtech's 24mm(0 offset) dish rims on their site so I'll be trying them out soon. They're $5.49 for a 4pack.
Old 12-13-2001, 01:46 AM   #36
robk's Avatar
Trader Rating: 22 (100%+)
Modena AL-yeah the softer inserts can lead to greater wear but i think a lot of that has to do with driving and setup. If both are good it is much less wear than if you are abusing the tires.
Old 12-13-2001, 02:52 AM   #37
Anybody try the RDLogics pure rubber tire yet? I'm dying to try them.
Stika525 is offline   Reply With Quote
Old 12-13-2001, 03:01 AM   #38
Hey Stika525- I haven't tried them but I heard that they were heavy as hell. Don't take my word for it, this is just what I heard from rcracing.com. They don't require inserts.
Old 12-13-2001, 03:04 AM   #39
I was thinking that also. But I also considered that insert is also removed from the equation so the weight might not be that much of an issue. whatcha think?
Old 12-13-2001, 03:16 AM   #40
Corse-R's Avatar
Ummm... I don't know the surface of the snowbirds, but for the time being, my choose should be about these two tyres/inserts for winter season on asphalt:
ProLine 1095H13 w/ Yok ZR037-S.
ProLine 1095H13 w/ Stock blue foam.
I'm gonna test some Yokomo 'M' compound with soft inserts.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-13-2001, 03:19 AM   #41
Corse-R's Avatar
So what?
During the last year I've used 24mm velocity rims (dishes) for my rears and 24mm Gumby wheels.
Cheers,
Corse-R
Old 12-13-2001, 03:27 AM   #42
Surface will be Ozite carpet. If I'm not mistaken, I heard it'll be new. Pit and Sorex 20r and 24r compounds seem to be the hot ticket so far. I have tried the Sorex 24r front and 20r rear on asphalt and it worked great. A friend and I were dog fighting on the track with this combo and it made for some good passes. Used Echo red inserts in both.
Old 12-13-2001, 10:36 AM   #43
MikeR's Avatar
Trader Rating: 15 (100%+)
I've been shown that they're good for beating around the streets but WAY too heavy for serious racing... good way of overheating your motor too i guess...
MikeR is offline   Reply With Quote
Old 12-13-2001, 04:32 PM   #44
Corse-R- Thanks for the correction on the pro-line 24mm dish wheel. I could of sworn they only made the dish wheel in a 26mm inch-up. Glad to see your having good luck with them! What kinda of surface do you run/race the H13's w/blue foams on?
Old 12-13-2001, 04:37 PM   #45
sosidge's Avatar
Stika - I'm not a rubber tyre expert, but some guys from my (carpet) club went to a couple of outdoor meetings with the solid tyres, and the tyres came back wrecked - overheating I think was the problem, and they were good for nothing afterwards.
Question - I run narrow yellow schumacher minipins, cos I run indoors. Does anyone know of...
1. moulded inserts for 21mm tyres?
2. Nice stiff 21mm wheels without an offset?
thanks
1/10 Offroad Tire and Insert Thread racenut123 Electric Off-Road 40 09-24-2008 09:14 PM
** Tire - Insert - Wheel SALE!! ** -NIP- NEW & used c1 racin R/C Items: For Sale/Trade 20 06-29-2007 07:39 AM
Tamiya Tire / Insert / Wheels (NIP) tamiyatrf R/C Items: For Sale/Trade 0 01-02-2006 01:54 PM
What Tire & Insert Combination For Hot Asphalt FREAKAH Electric On-Road 22 08-26-2003 10:28 AM
MoMo Tire Insert.................. Barry White Electric On-Road 0 03-18-2003 05:51 PM
