problem with an old car >
Old 11-10-2007, 11:41 PM
Angry problem with an old car
I had an old car that keeps turning left with out me using the remote.If I turn it on it turns left automatically.I used the trim settings and it dosent do anything.Also the run time is very short.
sk8boarder is offline
Old 11-11-2007, 01:29 AM
surrealmaterial's Avatar
to fix the steering issue, you need to take the servo horn off, center the servo by setting you trim to center and putting the horn back on so the wheels are straight. Then adjust trim from there. To get more runtime, depending on which motor you are using, you need to use a higher capacity battery.
cheers
surrealmaterial is offline
