Old 12-08-2001, 10:00 AM   #1
dtm
dtm's Avatar
Send a message via ICQ to dtm
CS Powercheck
I have been offered a CS Powercheck dyno, used at a fairly reasonable price but I have a couple of questions hopefully someone will know the answer to;
1. The m/c starts up at v1.1 s/w is this the latest version? (the PC s/w is at v1.5 and I know that it is the latest)
2. I have been told by CS when running 10 turns or less to use 2 battery packs in parallel. Has anyone tried this and does it make the results strange?
3. What tips do you have using this unit?
Thanks in advance!
dtm is offline   Reply With Quote
Old 12-08-2001, 10:14 AM   #2
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: CS Powercheck
Thanks in advance!
the problem is that this dyno test the motor in vertical position while you run your motor in horizontal position. i do think this is not the way we should dyno a motor.
Manticore is offline   Reply With Quote
Old 12-08-2001, 10:16 AM   #3
dtm
dtm's Avatar
Interesting.... that gives me another idea for a test!! I'll let you know the results!
Old 12-08-2001, 10:19 AM   #4
Manticore's Avatar
dont tell me you are going to test a motor with the dyno in standard posiiton and in laydown position !
Old 12-08-2001, 10:21 AM   #5
dtm
dtm's Avatar
you read my mind! I'll make sure the flywheel is vertical first with a spirit level!
Old 12-08-2001, 10:24 AM   #6
ernestf's Avatar
Send a message via ICQ to ernestf
dtm, where u see the dyno ?
ernestf is offline   Reply With Quote
Old 12-08-2001, 10:26 AM   #7
dtm
dtm's Avatar
It wasn't displayed in the shops. Someone is getting rid of his electric stuff! I have the unit for a 'test run' this weekend.
Old 12-09-2001, 06:14 AM   #8
dtm
dtm's Avatar
Manticore- well I did do the test! With the motor vertical the max power comes in at around 2000rpm higher than in the horizontal position, the actual power level was very comparable. Besides that there was very little difference between the two tests. Max power, amp draw, rpm etc was very comparable.
Old 12-09-2001, 06:18 AM   #9
dtm
dtm's Avatar
I also did the 1 pack/2 pack test. Strangely enough, running 2 packs give a much flater efficiency curve (only for the first half of the run). The max efficiency level was pretty close.
The power curve also shifted a little. I don't think you can compare the results! but I guess if I consisitently use 2 packs for 8 and 9 turns then I can compare! hmmmm... strange findings! The motor also seemed to accelerater harder with 2 packs (just by the sound!) but I guess that would be normal.
Old 12-09-2001, 07:46 AM   #10
Manticore's Avatar
well accuracy is a definite problem with the CS dyno. I think this is a way CS makes their customer happy. 2000RPM is a hugh difference.
Old 12-09-2001, 08:26 AM   #11
dtm
dtm's Avatar
I did two runs with the motor horizontal and 2 with the motor vertical. On both occasions the vertical positions power peaked at around 2000rpm higher than the horizontal position. It was fairly repeatable (within reason!).
Old 12-09-2001, 08:28 AM   #12
dtm
dtm's Avatar
Max power was around 21,xxxrpm and 23,xxxrpm resp. so 2,000rpm would put it in the 10% region.
cs powercheck instructions? stephen hilton Electric On-Road 4 03-02-2007 04:13 PM
Dyno - CS Powercheck CGR R/C Items: For Sale/Trade 3 08-16-2006 08:47 PM
WTB CS Powercheck or CE TurboDyno45 mtveten R/C Items: Wanted to Buy 9 10-31-2004 09:06 PM
CS PowerCheck motortester ?????? Sandor Electric On-Road 2 11-15-2001 06:40 PM
