Old 12-07-2001, 10:35 PM   #1
carpet_killa's Avatar
Default i got a comm lathe but 1 more ???
i got a comm lathe now but i have a question? what kind of motor do i need to run my comm lathe .i got a xipp mod comm lathe from integy for a good price i guess.thanks for you alls input///
carpet_killa is offline   Reply With Quote
Old 12-07-2001, 10:42 PM   #2
wonderboy's Avatar
Default motor for lathe
Hey carpet I have the same lathe and really like it. I bought one of the cheap stock Integy motor for it and run it off a 4 cell pack. Integy also offers a 55T motor that you can use with a 6 cell pack. I get great results using a stock motor and 4 cells. This set-up spins the armature just right to get clean cuts.
wonderboy is offline   Reply With Quote
Old 12-07-2001, 10:46 PM   #3
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
For best results on any lathe, get an old mod can, and stick and old stock arm in it. Set the timing to 0. This way you have a very smooth and quiet motor
Speedo is offline   Reply With Quote
Old 12-07-2001, 10:46 PM   #4
Send a message via AIM to ZER01
Stock motors are fine, just make sure the timing on the drive motor is set to 0 degrees if the motor needs to be run in reverse.
*TIP*- use brushes that are the easiest on comms. There's no reason your drive motor needs blistering torque and top end to spin some arms. I use trinity's hard copper brushes. The reason for this you want the drive motor to last as long as possible. I beleive mine should last about 5 years with the amount of cuts I do.
ZER01 is offline   Reply With Quote
Old 12-07-2001, 10:59 PM   #5
Moderator
Speedo's Avatar
You can't set stock motors to 0 degrees of timing
Old 12-07-2001, 11:02 PM   #6
OOps- my mistake, if you make up a motor(in my case) using a mod can and stock arm, be sure to set the timing to zero if the motor needs to run in reverse. Thanks for the correction Speedo.
Old 12-07-2001, 11:06 PM   #7
Trips's Avatar
Trader Rating: 16 (100%+)
You can't? I have no trouble at all setting stock motors to any amount of timing. Except the Epic cans with flat sides, of course.
Trips
MARSHAL!!
Trips is offline   Reply With Quote
Old 12-07-2001, 11:51 PM   #8
Moderator
Speedo's Avatar
Well, I was talking specifically about the epic cans really...But, I prefer my method of using the mod can, much quieter
Old 12-08-2001, 12:16 AM   #9
Default reply
i don't have any mod motors , i only have 3 stock motors. a p2k pro and mvp ,and a new p2k2 pro. but i have an extra 6 cell pack and does it matter if the battery pack is matched,it is a pro match battery pack smh 3000 average volts are 1.143 on each cell.but just woundering.will it just be easer to get a certain motor.if so just tell me,and i will do that then.thanks
Old 12-08-2001, 04:00 AM   #10
Regional Moderator
Addict sa RC's Avatar
You can get one of those Mabuchi or Johnson motors. Those would be fine.
Addict sa RC is offline   Reply With Quote
Old 12-08-2001, 06:05 AM   #11
Yokomo Fan's Avatar
just use a mabuchi 540 motor from ye' ol' tamiya kits
Yokomo Fan is offline   Reply With Quote
Old 12-08-2001, 06:08 AM   #12
AE_Racer's Avatar
Send a message via AIM to AE_Racer
carpet, no need to use a good battery on it bud, just go buy a $15 stick pack and use it
AE_Racer is offline   Reply With Quote
Old 12-09-2001, 09:44 AM   #13
I wish someone had told me I bought a matched 4 cell 3000 smh pack and dyno tuned stock motor.... LOL I actually got a 17 turn speedworks motor with my lathe and use 4 old 1500 cells to power mine... But I do have to believe that a 4 cell NI-MH pack would be better, because you don't ever completely run down the batts when using the lathe.
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 12-09-2001, 09:56 AM   #14
Moderator
Speedo's Avatar
LOL, you bought a SMH pack to run it...hehe...Better yet, get a T35 or something similar, then you never run out of power
Old 12-09-2001, 12:09 PM   #15
Default reply
no i didn't go buy a pack of smh's to run it i just have an extra pack to spare , that are low #'s anyway.......
Trinity Tru Lathe Motor Comm Cutter Lathe maximum R/C Items: For Sale/Trade 4 05-14-2007 04:56 PM
Hudy comm lathe and Fantom comm lathe ACEDEAN R/C Items: For Sale/Trade 0 05-02-2007 11:27 AM
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 12:53 PM
Trade EXTREME COMM LATHE(Hudy)for MUCH MORE COMM LATHE JoeyE R/C Items: For Sale/Trade 0 05-07-2006 09:49 AM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 01:07 PM
