SpeedMerchant Rev 5 >
SpeedMerchant Rev 5
SpeedMerchant Rev 5
Old 10-28-2009, 06:21 PM
  #526
Trader Rating: 37 (100%+)
Josh Keller is offline
Old 10-29-2009, 05:32 AM
  #527
theisgroup's Avatar
Originally Posted by Josh Keller
Any idea on what receiver pack is in Mike's Rev 5?
http://www.teamtekin.com/race/2009/i...ture%20012.jpg
Josh
if you are talking bout dumas, that is not his car. he runs a custom rx pack. it was made from 2 eflight packs soldered together
theisgroup is offline
Old 10-29-2009, 03:39 PM
  #528
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Josh
If you look carefully you can see a D and an L on the side of the pic as well as Donny Lia etched into the motor plate. FYI. I dunno what receiver pack he was running though.
andrewdoherty is offline
Old 10-29-2009, 07:44 PM
  #529
Old 10-29-2009, 08:17 PM
  #530
I saw that on the pod plates. I was just was going from what the Tekin website stated.
Josh
The spektrum2 receiver is a giveaway. The website must just be labled wrong. Regardless, I don't know what receiver it is.
Old 10-30-2009, 05:21 AM
  #531
theisgroup's Avatar
Josh
i think he told me that it was the losi pack for their micros
Old 10-30-2009, 10:48 AM
  #532
timmay70's Avatar
Donny's rx pack was most likely a Micro-t Losi pack...
timmay70 is offline
Old 10-30-2009, 11:21 AM
  #533
Donny Lia's Avatar
that pack i made from 200mah cells i got from batteries america. worked ok but not really worth the time to build it. im using a micro t pack now
Donny Lia is offline
Old 10-30-2009, 11:31 AM
  #534
timmay70's Avatar
Where the hell are ya? Your pit spot is ready, and the tire truer is warmed up...
timmay70 is offline
Old 10-30-2009, 11:40 AM
  #535
Donny Lia's Avatar
LOL! she's warmed up? nice. unfortunately im not going to make it bud. sal couldnt make it and just had bunch of stuff i had to get done anyways. good luck!
Old 11-10-2009, 08:29 AM
  #536
I was asked to post my setup from the Halloween classic so here it is. Bumpy track with lots of teardrop 180's. Finished 3rd in 17.5.
Front:
Dbl pink tires. Glued full face.
Middle/Middle on formula front end with high roll center cones
-1.25* Camber, 4* Caster
.018 springs Green spooge on kingpins
3.5mm ride height
Center:
Hot bodies shock
Losi 25wt oil
Red center spring
green Tube spooge
.021 side springs 3/4th turn preload
3.5mm ride height
High roll center cones
2* pod droop
Rear:
Gray tires Glued full face.
3.5mm ride height
Parma speed8 lw Body
JoelV is offline
Old 11-10-2009, 12:22 PM
  #537
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
Joel had a great run at Cleveland and better yet drove very cleanly in tight confines.
Joel - do you remember the tire sizes you were running? and what esc and motor where u running?
hanulec is offline
Old 11-10-2009, 01:26 PM
  #538
1.70/1.63 Tires. Tekin RS with a duo. 72/45 no timing in can. 20 boost/20 turbo. Looking back I don't think I hit gearing quite as well as I did car setup. They were carrying more timing and gear.
JoelV is offline
Old 11-10-2009, 01:38 PM
  #539
CypressMidWest's Avatar
You drove great all weekend, and your car was plenty fast.... It was great battling it out with you in the Main.
Who's "they"? I was running more gear, but less timing and boost. Car seemed to carry the laptimes deeper into the run that way. I realized on the way home that I missed my gear by a tooth in the main, DOH! Changed rears and didn't remember to gear down.
CypressMidWest is offline
Old 11-10-2009, 01:39 PM
  #540
Kwikvdub's Avatar
Trader Rating: 100 (100%+)
Hey Joel,
Car looked locked in in the Main!........ Seemed your car was getting better and better with every run throughout the weekend!...... Great job Bro!
........Way da represent with so many CRC's on the A Main grid.
Kwikvdub is offline
