Old 11-10-2008, 06:20 PM   #271
That is the car based off the speedmerchant right? The front end holes have not changed in distance from the rev4 to rev5 as I'm still using a rev4 chassis. Only difference is the servo is slightly back in the rev5.
JoelV is offline   Reply With Quote
Old 11-10-2008, 06:31 PM   #272
hanulec's Avatar
Trader Rating: 27 (100%+)
Originally Posted by RCSteve93 View Post
What car? I am pretty sure on most cars it is pretty standard. I know the front end fits the BMI, CRC and Associated 1/12ths.
hi steve - while the bolt pattern for 1/12th scale cars front ends are mostly the same front to rear their width are not. The BMI is not the same width as the SpeedMerchant (I know that from experience). I cannot speak to the CRC.
the formula front end is probably my favorite part of the Rev 5. no more silly uneven plastic arms.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 11-10-2008, 06:34 PM   #273
hanulec's Avatar
Originally Posted by hanulec View Post
Hot off the presses - aluminum pod plates are now available from Speed Merchant!
Part #smr1465 Rev 5 - World GT Aluminum Pod Set(Black) $49.95 $49.95
http://www.teamspeedmerchant.com/sho...l/smr1465.html
I saw the production version of these plates on Sunday. They look really nice! Your local hobby store should have them -- and if not 360 RC Speedway has them in stock.
Old 11-11-2008, 05:27 AM   #274
The width is the same as the old CRC C.K. on the new GenX Frank
change it to widen.
hanulec
"the formula front end is probably my favorite part of the Rev 5. no more silly uneven plastic arms."
I agreed. no matter how good the molds are plastic shrink, to get it on the tenth
CNC i need.
Alf :-)
alf.skaar is offline   Reply With Quote
Old 11-11-2008, 09:38 AM   #275
Alf,
Just went out and got my calipers to measure the chassis here on my desk and it is the same as yours center to center. I didn't want to tell you yes without measuring, but I knew it'd be the same when you said carpet knife.
Old 11-12-2008, 02:06 AM   #276
Alf,
Then the old C.K and Rev4 is the same center to center.
Thanks to all for the help
Alf :-)
Old 11-13-2008, 10:32 AM   #277
Carl Giordano's Avatar
Trader Rating: 24 (100%+)
latest creation by the master builder Mike O'Donnell. His building is second to none. I just raced the Brushless Rev 4.5 he built for me and it was perfect...can't wait to race this at 360 Raceway in Long Island, NY.
SpeedMerchant Rev 5-rev-5-.jpg   SpeedMerchant Rev 5-rev-5-b-.jpg   SpeedMerchant Rev 5-rev-5-c-.jpg
Mugen Racing / OS Engines / KO Propo / Byron Fuels / Schuur Speed Motors / AKA / Bruckner Hobbies / Tamiya M-Chassis / Kyosho / Yokomo / 360v2 Raceway / Cruzin with RC
Carl Giordano is offline   Reply With Quote
Old 11-13-2008, 11:37 AM   #278
360rcspeedway's Avatar
Default Nice
Carl,
Nice ride, can't wait to see it out there! If you need any help let me know. It was great to see you out there running good last week..rough main though huh?? lol
-Donny
360rcspeedway is offline   Reply With Quote
Old 11-13-2008, 12:41 PM   #279
Goingfast's Avatar
Trader Rating: 29 (100%+)
Hi
Can someone posted their latest setup for carpet? ( speaking of REV5 and4.5) Thanks
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 11-13-2008, 12:42 PM   #280
Goingfast's Avatar
Nice
Old 11-13-2008, 01:06 PM   #281
Originally Posted by Goingfast View Post
Hi
Here is something that should be in the ballpark anywhere on carpet:
Front:
.020" Springs
1.5 Dg. Camber
3.5 Dg. Caster
1 dg. toe-in
Camber/Caster Links mounted middle/middle
3.5mm Ride Height
Green Spooge on Kingpins
Jaco Lilacs - 1.67"
Mid:
Old School tall antenna mount (to get correct shock angle)
35wt
Red Spring
2mm pod droop
3.5mm Ride Height
Battery back
Rear:
172mm track width
4mm Ride height (measured at rear of pod)
Red Spooge in dampener tubes
.23 Side springs, backed 1/2 turn off side links
Jaco Yellow's - 1.75"
Start with 1/2 dope front tires, full rears. If you need more steering go to 2 dg. camber. If you need even more go to double pink fronts.
Hope this helps
Old 11-13-2008, 04:52 PM   #282
SpeedMerchant's Avatar
"Latest creation by the master builder Mike O'Donnell."
OD is a freak. LOL.
Awesome job as always.
SpeedMerchant is offline   Reply With Quote
Old 11-13-2008, 06:16 PM   #283
odpurple's Avatar
Originally Posted by SpeedMerchant View Post
OD is a freak. LOL.
Hey! I resemble that remark
TOP Racing USA--OD Racing--Novak--Power Push--J Spec
odpurple is offline   Reply With Quote
Old 11-13-2008, 11:42 PM   #284
Goingfast's Avatar
Front:
.020" Springs
1.5 Dg. Camber
3.5 Dg. Caster
1 dg. toe-in
3.5mm Ride Height
Jaco Lilacs - 1.67"
Mid:
35wt
Red Spring
2mm pod droop
3.5mm Ride Height
Battery back
Rear:
172mm track width
Hope this helps
Old 11-21-2008, 03:53 PM   #285
Trader Rating: 26 (100%+)
can someone explain how to get the caster adjusted accurately. thanks
and how do you check what degree its at
eddie10 is offline   Reply With Quote
Speedmerchant REV 4.0 rraden R/C Items: For Sale/Trade 7 10-12-2007 07:29 PM
*** 1/12 Speedmerchant 4.0 *** rraden R/C Items: For Sale/Trade 28 09-29-2007 06:46 AM
WTB CRC Gen X or Speedmerchant 4.5 rraden R/C Items: Wanted to Buy 7 06-05-2007 06:56 PM
Speedmerchant v4, Speedmerchant replica....and more BlackKat R/C Items: For Sale/Trade 4 07-25-2006 06:47 AM
Speedmerchant rev 4 BritRacer R/C Items: Wanted to Buy 1 02-28-2006 08:41 AM
