SpeedMerchant Rev 5
#232
AWD - go here and look at the list under the three different categories at the bottom. It has pictures and item numbers.
http://www.teamspeedmerchant.com/shop/shop.html
#234
#236
#237
R/C Tech Elite Member
Got my replacement Rev 5 chassis this weekend. Bruce and a bunch of the RCE guys were down at 360 RC Speedway getting ready for Vegas. The SpeedMerchant web site has been updated w/ the part now.
http://www.teamspeedmerchant.com/sho...l/smr1419.html
One piece of caution, this part number also used to be for the Rev 5 chassis -- so I would make sure the chassis is named Rev 5.
#238
Peedmerchant Rev 4/4.5
I am going to be drilling a couple speedmerchant chassis for this season a 4 and 4.5 for the old school front-end. From checking the various pictures of setups what angle do I want to tie rods? I will be using Jr 3550 and 3650 as servos. Straight across from servo saver, medium swept forward or most swept forward position. We will be running on carpet with taped seems.
Or due to the tape bumps should I run the 12l4 type front end.
Tom
Tom
#239
Tom
Tom
Proper linkage angles can be obtained by attaching the servo mounts and servo saver. Center the servo saver on the chassis as far forward possible. Leave just a slight gap from the suspension block to the screw (I use button heads) that mounts the servo to the servo mount. Mark and drill your holes.
I usually put a piece of masking tape on the chassis for marking purposes. To be sure that the hole locations are square on the chassis, use a pair of calipers to lightly scribe the tape, measuring from the front edge of the chassis to the hole center lines.
