Old 09-19-2007, 07:02 PM   #1
hanzo3's Avatar
Trader Rating: 55 (100%+)
Default Futaba S9550 problem
I just got a new S9550 and plugged it in to my rx. Turned it on and it did not move. It did not respond to any steering. It is making a low humming sound. Anyone know what the problem could be? I am using a Spektrum DX2.0. On the box it says it's for NiCD batteries only, is this true?
hanzo3 is offline   Reply With Quote
Old 09-19-2007, 07:23 PM   #2
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
check that you have it pluged in the correct way maybe??
Perhaps you have it plugged into the wrong chamel ? (see if the servo moves with the throttle)
Old 09-19-2007, 07:29 PM   #3
hanzo3's Avatar
Well I was using a HS 645MG before.
Old 09-19-2007, 07:42 PM   #4
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Well The servo will may a low humming noise. I think most digital servos do. So the noise is not the problem but you may have a problem with your receiver. I would make sure you signal wires are the same as the Hitec servo you were using.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-19-2007, 07:48 PM   #5
HACHIROKU13BT's Avatar
Default S9550
The transmitter your using is the Spektrum 2.0 dx. Isn't that on analog, similar to PPM? And since the S9550 is a digital servo, hence the humming. Shouldn't the digital servo be run on HRS? Not compatible.
HACHIROKU13BT is offline   Reply With Quote
Old 09-19-2007, 07:54 PM   #6
I read your first post again. I actually have the exact same setup (DX 2.0 and S9550)...and mine worfs fine.
Old 09-19-2007, 08:06 PM   #7
hanzo3's Avatar
Did you have to cut off the tabs to make it fit?
Old 09-19-2007, 08:23 PM   #8
I cut the tab off a while ago (I've had my s9550 for over 3 years)...so yes you may have to do that.
Old 09-19-2007, 08:27 PM   #9
Regional Moderator
Darkseid's Avatar
No, its the other way around.
If you run HRS, you must use digital servos.
But digital servos themselves can be used with any radio type.
TLR 22...Tamiya F104...
Old 09-19-2007, 08:35 PM   #10
Trader Rating: 16 (94%+)
Ditto. Same stuff works fine for me too. It's possible that you got a bad servo, just be sure to check the pins in the receiver aren't bent, and that you have the positive/negative lined up correctly.
kn7671 is offline   Reply With Quote
Old 09-19-2007, 08:57 PM   #11
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Mine does also
It hum's and little but thats all
Is it possible you could try the servo of someone elses radio or something? To make shure its the servo and not something else
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 09-20-2007, 12:52 AM   #12
hanzo3's Avatar
If I shave off the edges, and switch it so it has a reverse polarity, would that work? I just want to make sure before I shave the connector. I bought this servo new from a member on this board. Should I return it to futaba?
Old 09-20-2007, 01:13 AM   #13
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
make sure your RX didnt unbind itself to your radio. Digital servo hum when there is resistance to the gear side to side if you turn it. when there is no resistance, its quiet
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 09-20-2007, 09:44 AM   #14
racer34v's Avatar
Trader Rating: 126 (100%+)
Send a message via Yahoo to racer34v
i agree rebind your tx/rx first!
racer34v is offline   Reply With Quote
Old 09-20-2007, 09:48 AM   #15
racer34v's Avatar
also try another servo
Futaba S9550 prettyinpink Australia For Sale/Trade 1 07-27-2008 11:44 PM
wtb: Futaba S9550 ernieball R/C Items: Wanted to Buy 0 05-13-2007 09:52 PM
WTB: Futaba s9550 OR Futaba s9451 rays_tt Australia For Sale/Trade 0 09-02-2006 01:31 AM
Futaba S9550 Rody Australia Wanted to Buy 4 05-06-2006 07:13 AM
Futaba s9550 BritRacer R/C Items: Wanted to Buy 2 01-03-2006 09:52 AM
