Old 09-18-2007, 06:56 PM   #1
bxpitbull's Avatar
Default A question about gear meshing
I am running 64p on my Pro4 100spur/26pinion. Now, I adjust the mesh according to what has been sited many times (paper in between the teeth, not too tight, not too loose). My problem is the sound....sounds like I am running 48p. I call it the "dirty whir".....after you run a truck in the dirt, it has the light grinding sound. Initially, I though it was the diffs and/or the tranny. Without the motor set in the motor mound, tranny is smooth as butter. Any suggestions? I like my electric to be quiet...not with the "dirty whir".
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 09-18-2007, 07:27 PM   #2
gubbs3's Avatar
I don't ever use the paper trick for 64 pitch gears. Most paper is too thick and allow too much backlash. That can also cause a lot noise. If you are going to use paper, try newspaper. Personally I just eyeball mine so there is just the slightest "tick" between gears. Make sure you also rotate the gears and set the "tick" at the tightest spot.
gubbs3 is offline   Reply With Quote
Old 09-18-2007, 08:02 PM   #3
Uga
Uga's Avatar
Have you tried another spur? Maybe it's too tough or low quality.
Uga is offline   Reply With Quote
Old 09-18-2007, 08:18 PM   #4
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
If you are using a 26 tooth spur do this...Take a 27 tooth spur and tighten the pinion to the spur and make the mesh tight. Then remove the 27 tooth pinion and put on the 26 tooth pinion. Your mesh should be spot on after that.
It works for me...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-18-2007, 09:52 PM   #5
bxpitbull's Avatar
The xenon hpi/yokomo 64p and rrp pinions.
Old 09-18-2007, 09:54 PM   #6
bxpitbull's Avatar
Pit you have a good idea there. I will try that. Thanks everybody.
I just quoted myself like duh.
Old 09-18-2007, 10:39 PM   #7
Super Moderator
Grizzbob's Avatar
Agreed, I've noticed that some brands of spur just make more noise with certain brands of pinion, so you might try more mixing & mnatching brands to see if that affects it(personally, I like Kimborough's spurs with Robinson pinions, not exactly silent but it doesn't sound dirty either, & it's plenty smooth for my tastes).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-18-2007, 10:53 PM   #8
Roads's Avatar
I put the pinion and spur gear firmly togther and tighten the motor mount screws snug. Then I back the motor off just a tiny bit. I make sure that I have a small amount of play between the gears. Don't forget to retighten the motor. I have never tried the paper method. Seems like most paper would leave a large gap between the gears.
Team Associated TC5 - Teambr00d CO27, Futaba S9550, Novak Rooster, DSM
Roads is offline   Reply With Quote
Old 09-19-2007, 07:46 AM   #9
timmay70's Avatar
How profound!
Another thing, as gears wear down, they will naturally develop more lash even though the depth of the mesh appears to be correct. When this wearing of the face of the teeth gets deep enough, it will develop a noticeably louder tone.
good luck.
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Motor Gear Question sambora68 Rookie Zone 7 09-02-2008 08:03 PM
32 pitch gear question laro Nitro Off-Road 0 06-09-2008 03:13 PM
truggy spur gear question???and general truggy conversion.question. downunder23 Electric Off-Road 1 03-22-2007 09:09 PM
Gears not meshing right in TT-01 RSR Rookie Zone 2 02-24-2006 08:58 PM
64 pitch gear meshing GReddy Electric On-Road 12 06-16-2005 08:06 PM
