Old 05-14-2003, 04:29 PM   #16
KO Propo use 1000uF capacitors but they are rated 35v. Why is this? It only makes it bibber and more heavy. No?
Black Adder is offline   Reply With Quote
Old 05-14-2003, 06:22 PM   #17
kaizen's Avatar
Can we get an answer or pic (as suggested by doublest) on how this is done? I am especially curious to how the parallel setup looks/works. e.g. does one simply solder the negatives and positives on the capacitors together and attach to the negatives and positives on the ESC, or is some other voodoo required.
Please advise.
Thanks in advance.
Kaizen
kaizen is offline   Reply With Quote
Old 05-15-2003, 02:06 AM   #18
doublest's Avatar
Send a message via MSN to doublest
As jcr said, does it make much of a difference in stock class.
Cheers
P.S. gets sum pics on here
doublest is offline   Reply With Quote
Old 05-15-2003, 09:46 AM   #19
Speed Demon's Avatar
I've just soldered the 2 x 4700 caps in parallel and wired them up to my GT7.
Do you mean that the capacitor that comes with GT7 is also rated 4700uF?? how about the voltage rating???
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 05-15-2003, 02:49 PM   #20
kaizen's Avatar
The information that i have received is that is does make a difference in stock as well as mod - result being more punch on the higher uF capacitors.
One would presume that since a stock motor may exhibit many of the same characteristics (in terms of "draw" -- considering additional drag associated with bushings and "higher" winds) as a modified motor, that an ESC would benefit from power capacitors regardless of whether it is attached to a Mod or Stock motor. But, I am no EE. Neverthless, I will be testing this theory this weekend.
Regardless, it is a relatively inexpensive mod and (as I see it) is worth experimenting with. I picked a couple of 4700uF 35V units yesterday from my local Electronics Store for about $5.25 (US) each.
Cheers, Stu
Old 05-15-2003, 02:53 PM   #21
jcr
ok a low impendence and high frequency capacitor, isn't that low ESR capacitor? If so isn't it harder to find those (since most electronic store don't have it or the ones i've looked at)?
or can we just use any capacitor?
jcr is offline   Reply With Quote
Old 05-16-2003, 05:03 AM   #22
Send a message via ICQ to JesseT
A power capacitor makes a huge difference at partial throttle settings, no effect to full throttle power, not punch not acceleration. This is all dyno tested to back my theory. There should also be an older thread on this topic.
JesseT is offline   Reply With Quote
Old 05-16-2003, 05:25 AM   #23
yes it is a low esr capacitor.
90% of the time you can use any capacitor, and i've used a variety without any ill effects. if you get one that can't hack the pace then apparently they blow up but don't cause any harm to the speedo. i can't verify this as i've nver blown one up though.
sanj
schumacher is offline   Reply With Quote
Old 05-16-2003, 06:43 AM   #24
Cole Trickle's Avatar
Originally posted by MattW
From a capacatance point of view yes 2x4700uf caps in parallel would be the same as a single 9400uf. However the 2 caps would have much higher impedance that the single cap. In capacitors impedance goes down as capacitance goes up.
For info the large cap in the LRP worlds kit is 4700uF, and certainly looks to me to be a Panasonic made cap.
Yes, but impedance will also be lowered when you parallel caps. 2 4700 in parallel will have half the impedance of one 4700. 3 gives one third impedance and so on.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 05-16-2003, 04:58 PM   #25
Higher voltage capacitors have higher impedence. Use a 10 or 16 volt capacitor.
Higher voltage readings, thus higher voltage to cross the cap. Impedence is resistance to alternating current. its not exactly the same as resisitance to direct current.
Pit Crew is offline   Reply With Quote
Old 05-17-2003, 04:45 AM   #26
Here`s a pic of my mates TC3, he uses a 16v 10000uf powercap on his speedo.
I will get some pics up on my car to when i get hold of a digicam...
Tamiya FF03 Pro
Xray XII Link
3 Racing F1-09
Hatebreed is offline   Reply With Quote
Old 05-22-2003, 12:57 PM   #27
dirk's Avatar
Lightbulb
This thread is very informative...this is all new to me.
I have a Novak 410-M5 esc, where would I solder the tabs of the cap to the esc? Thanks for any info.
dirk is offline   Reply With Quote
Old 05-22-2003, 01:37 PM   #28
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
using a 10000 uf capacitor on my cyclone esc and a p2k 2 pro motor
will it fry it
same with a mvp motor and a futaba MC230CR (lower class futaba esc)
Calvin Ng is offline   Reply With Quote
Old 05-22-2003, 01:55 PM   #29
I've just got a large dent on my power capacitor for my Novak TC2. Since I need to replace one I would like to know
where can I buy one in States other than from Novak or Radio Shack? any Online store?
Thanks,
D.
DoCoMo is offline   Reply With Quote
Old 05-22-2003, 03:22 PM   #30
Try www.allelectronics.com they have them cheap and ask for the catalog.
MaddogTL is offline   Reply With Quote
Power Capacitor simba350 Australia Wanted to Buy 9 06-04-2006 04:53 AM
Bad Power Capacitor??? 2BAD4ALL Electric On-Road 4 11-24-2004 11:59 AM
Power Capacitor ?? T.SATO Electric On-Road 10 04-12-2004 05:18 PM
Power Capacitor T.SATO Rookie Zone 7 04-08-2004 04:49 PM
power capacitor - TC3 Brazilian Electric On-Road 11 01-12-2002 08:24 AM
