Old 09-19-2007, 10:28 AM   #76
bxpitbull's Avatar
Jack, I have re-read the thread and you have not tried to manipulate or mis-lead. However, you have to understand the hesitation by many of lipos without a hardcase AND one that is that high priced. If I am going to pick a high priced lipo, Orion will be it. Not so much because they are backed by Kokam(some serious players in the game) but the hard casing is more readily accepted. Seeing that I race locally, 152.99 is a bit out there when Maxamps, who have been at it for a few, has the 6000mah for $100. Your performance, run time and durability must be off the chain.
R40-Pondering a new Red Dot
Hara Pro4-GTB/3.5/Max Amps-yea.
Pondering moving on to Xray-have to go with a winner. If you cant beat em, join em!
I gear to run and win, not to THERMAL!
bxpitbull is offline   Reply With Quote
Old 09-19-2007, 10:34 AM   #77
Originally Posted by or8ital View Post
Im sorry you disagree with me (and I think others) on this thread about how responsible a statement like "just try it and find out" sits when people wanna know about safety. All anyone asked for is more information so they can make an informative decision about your cells. Your inability to answer those questions is the only thing that can be seen as misleading. I have no ill-will towards SMC. Im sorry you see it as such. I thought this was a forum to ask questions and learn but apparently it is a forum for sheep that should take whatever someone tells them they should.
Thanks for the kind words.
Jack Rimer is offline   Reply With Quote
Old 09-19-2007, 10:39 AM   #78
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
7.4 volts? why?
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 09-19-2007, 10:47 AM   #79
Trader Rating: 38 (100%+)
Originally Posted by DavidAlford View Post
7.4 volts? why?
Thats what all lipos (for rc car use) are.
or8ital is offline   Reply With Quote
Old 09-19-2007, 10:48 AM   #80
Leodis's Avatar
Trader Rating: 16 (100%+)
7.4 volts? why?
Did you want a 3.7v pack, or are you a 6v guy who wants to force lipo mfg'ers to come out with 3v cells just for a niche of a niche of a hobby, or do you want lipos to have a nominal voltage of 7.2v unlike all the NIMH race packs being sold these days?
Leodis is offline   Reply With Quote
Old 09-19-2007, 10:52 AM   #81
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Thats what all lipos are.
And newer NIMH packs are more than that.
I ran my Orion 3200 Lipo back to back with my SMC IB4200 in 19t Truck this weekend. Running the IB cells is like dropping a wind or 2 on the motor.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 09-19-2007, 10:54 AM   #82
Zing! You guys are ornery.
rain in our room
undark is offline   Reply With Quote
Old 09-19-2007, 11:04 AM   #83
Until the hardcase paranoia goes away, we are going to have to hear about how they need hardcases BS. At least li-pos have been accepted and is taking over the RC ground world now!
I have used soft packs for over 4 years now in everything from 1/10th scale stadium trucks to 1/8th scale buggies and have yet to see one on fire or explode. I have had them thrown out at high speed, drug them around the track and have broken chassis in half with no problems.
Just look at the World's Fastest RC Car Record last year was set with 8 soft cells stacked up on top of each other in 2 different cars crashing both into the barrier walls with the first crash was in a car at over 130 mph that Nic Case reused the same batteries in a 2nd car crashing on a run at over 160 mph with no cells catching fire or exploding. I'll bet Nic reused them after that!
Soft cells were used in ROARs Off-Road Li-po Brushless Truck Class at the Nats this year with no problems.
To sum it up a hardcase should be user optional and not required by rules.
Craps is offline   Reply With Quote
Old 09-19-2007, 11:08 AM   #84
wfdfiremedic's Avatar
not trying to start a debate between hard case/non, but don't almost all the 1/18th guys use soft shell lipos? I have used them without any incident.
wfdfiremedic is offline   Reply With Quote
Old 09-19-2007, 11:15 AM   #85
Any chance of SMC coming out with an 8000 mah 2S pack?
That will be closer to a 6 cell nickel pack weight and can not only have longer runtimes, but can be recharged faster (8 amps) after a 5 minute race.
We are using 8000 mah packs in 20 minute races around here.
Old 09-19-2007, 11:24 AM   #86
Send a message via ICQ to Jan Larsen
I echo what Craps said about the 8000mah possibility. An 8000 usually weighs around 360-400 grams which is right where 6 NIMH cells are.
14,8 volt versions would be accepted aswell...
Jan Larsen is offline   Reply With Quote
Old 09-19-2007, 11:38 AM   #87
bxpitbull's Avatar
That would be a fine idea, but for touring cars, space becomes an issue.
Old 09-19-2007, 11:42 AM   #88
I test some yuntong 5000 hard case charged to 8.5V and discharged to 3.9V full load 20C
i dont know how he make it but the cell resist very good to this treatment
i charge it at 2C to 8.5V and the pack give 0.2V more moy on 60A disch
it is not a spam
i drive xxx-4 for one year and jrx-pro since 15 year
dgaumond on
www.rcfanatic.com
ironxxx4 is offline   Reply With Quote
Old 09-19-2007, 12:05 PM   #89
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
I personally don't have any concerns over hard case or soft. But, my local track does not allow us use drive with soft shelled lipos. You referenced ROAR in your post and I thin k when/if ROAR comes out will rules for lipos hopefully they will mention how the battery is packaged. I think this will help battery companies decide what they are going to do. Not that I care for ROAR rules but most tracks abide by most ROAR rulings.
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-19-2007, 12:44 PM   #90
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
Eventually they will come around and see the light of day. Planes, cordless phones, helicopters and all use soft cased lipo's. This is basically a bunch of bs that has made team orion a lot of money. Come on, have some balls and wuit being sheep led by r/c car action, and uneducated forum people. Hard case is more protective I won't argue that, but it is not an absolute by far. Let's have an open mind about these cells. And be thankful that the technology hit the sport. 10min races are now a viable race in touring 13.5 turn. That gives you 2x the driving time on race day. Instead of trying to throw more hurdles in the way of the lipo cells, lets band together to legalize all forms of lipo's and push to build classes that race them. They are the future, and when they have been using them in planes and Heli's for years with soft cases, then we know that it is a tried and true technology.
Seriously guys lets get together on this and end the conflict.
No sponsors. Love TLR, OS and Futaba though
bigemike is offline   Reply With Quote
Core RC 5000mah Lipos... Nexus Electric On-Road 615 11-05-2008 08:03 AM
SPC 3s 5000mah bobby74 Electric Off-Road 0 06-24-2008 04:18 PM
SMC 28C High Performance 4000mAh - 5000mAh Hardcase Lipos Danny/SMC Electric On-Road 420 04-24-2008 03:36 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
WTB 5000mah lipos (2) and a balance charger vrcoupe R/C Items: Wanted to Buy 0 01-29-2008 09:51 AM
