Old 10-19-2007, 03:26 PM   #601
Company Representative
Danny/SMC's Avatar
Thanks for the info guys.
One think we learnt when the sub-c cells increased in voltage was that this required a change in gearing or motor setup. I know with BL motors the setup is the same and can't be changed but I do think that gearing should be changed to use the increase or drop in average voltage.
The difference between an 4800 Orion pack and a IB4200 pack is atleast .30 volts so this should mean a gain in RPM when using the NiMH pack so this should require a different gear ratio.
Danny/SMC is offline   Reply With Quote
Old 10-19-2007, 04:04 PM   #602
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Default Lower C charge?
Linger, or possibly others;
I was pondering this today as I started to put some cycles on the new smc lipo. The charge rate governed by most chargers is a 1C rate. I was wondering, if I were to charge at .5C, would the cycle life possibly be extended?(It should I think in the long run) Would this lower charge rate cause a drop in performance? The reason I ask is because Lipo's do not get hot while charging, which is why their is no difference in power? The typical NIMH cells we run now, perform better as close to peak as possible, which is also when they are hot.
I hope I didn't open another can of worms, just looking to explore some opportunities.
Thanks!
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 10-19-2007, 04:21 PM   #603
Trader Rating: 38 (100%+)
Mike, so you know for next year, you get 16-17 min with a 13.5 geared the way its supposed to be (not the way we race) with the Orion 4800. Just a tip for next years Enduro
Originally Posted by swopemike View Post
I ran 3 hours of practice laps on rubber tires at a large outdoor track in mid-August this year with another racer. This was after having run an Enduro that day, so my batteries already had maybe 3 partial charge cycles apiece on them. I was using a Novak 10.5 with the standard sintered rotor and so was the other guy. I was using two IB4200 packs (1.5-1.7 IR, 1.241-1.243 V) purchased from Team Express at Paved Nats June 8th. I rested, discharged, equalized and recharged my IB's prior to running the practice session. The other guy was using Orion/Peak 3200 packs bought this season. We both had decent cars with smooth running drivetrains, and athough his was Tamiya and mine Corally, we were geared virtually the same (roughly 4.83 FDR).
We kept regrouping just before the back stretch every time we got apart. So we zipped down the backstretch over and over and over again, almost together. One following the other, back and forth. We had a great chance to see how our speeds compared.
With a fresh pack, I outpulled him by several feet (2-3 feet). Consistently enough we were sure I was faster.
After about a minute, the difference was pretty small. Maybe a foot in 100. It then evaporated and we were too close to tell. Sometimes I thought I was a little faster.
But as the run went on, I could tell I was losing ground. In a 5 minute race, I think it was almost too close to tell... I had the better hole shot, but he could pull me at the end.
This particular course is very open and flowing, 15' wide lanes, 120 x 70 or so.
When we have run at another track that is tighter and longer, there was more advantage to the LIPO. The NIMH2 seemed to fall off a little more. Of course they had another 2 months of runs on them. But the discharge curve of the LIPO clearly seemed flatter.
During the actual enduro, one of my teammates had an Orion 4800 LIPO. He went seemingly forever running his 13.5, way way longer than I could have, over 10 minutes, and with every bit as much punch as I think I had, until close to when he dumped, he finally fell off. Whereas my packs fell off much more markedly in comparison, slowing more and more through the run while pushing my 10.5 BL.
I never realized how much NiMH2 fell off in a race until I saw LIPO running. They fall off too, but the ones I have seen, do so much more gradually.
I realize it's not me running both types, but the subjective difference on the track was, although subtle, easy enough to pick up by watching the cars. Based on our club trophy races, I think in a race you could guess 2 out of 3 times (by watching) which drivers had LIPO and which drivers had NIMH2.
It would be interesting to compare the new 3600 to new 4600 cells. I imagine they are both pretty close when integrated over a 5 minute run, albeit with different discharge curves. Just a guess... actual test and track data would be nice....
or8ital is offline   Reply With Quote
Old 10-19-2007, 10:50 PM   #604
linger's Avatar
Thanks!
Hi Stephen,
No can of worms here.
Technically, you get a tiny bit more cycle life at 0.5C vs 1C charge, but the difference is so small, that it's not worth it. The cycle life degredation seems to be exponential. For example, some of the cells I tested had fantastic cycle life up to about 1.4C and then you really start noticing a dip at 1.5C and the dip becomes huge at 2C. It's highly dependent on the battery and it chemistry on how high of a charge it can accept.
Also, charging at a higher charge rate does not make it perform any better - it just takes away cycle life..
I used to be a spitter, now I'm a swallower. I graduated.
linger is offline   Reply With Quote
Old 10-20-2007, 12:06 AM   #605
Moderator
Originally Posted by linger View Post
Hi Stephen,
Linger-
Thanks for the reply, thanks for answering the performance versus charge rate issue. I will be charging my packs at .5C and then discharging to see if there is a difference in runtime, voltage, or IR. As you have stated, there should be no performance difference between a faster or slower charge rate. If this is true, which I am sure it is(just want to run my own tests for curiosity's sake) I will be charging my packs at a lower rate when I have the time if it will extend cycle life of the pack. Thanks Linger!
SMC Racing
Old 10-31-2007, 05:59 AM   #606
rraden's Avatar
Trader Rating: 235 (100%+)
What is the best Lipo balancer for these cells?
rraden is offline   Reply With Quote
Old 10-31-2007, 11:47 AM   #607
Danny/SMC's Avatar
As the cells are matched prior to building the packs I don't think there is a need for balancing. If you do want to balance it I believe the ElectriFly balancer from Great Planes will work.
Old 10-31-2007, 12:24 PM   #608
Moderator
I strongly recommend that when you have a balancer, use it everytime. Why would you want to potentially have one cell unbalanced due to lazyness? We have been selling the Astroflight Astro "Blinky" battery balancer. it is part number 106 from them. I believe they go for around 23 bucks and do up to 5 cell packs.
SMC Racing
Old 10-31-2007, 12:28 PM   #609
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Good quality Lipo cells shouldn't need to be balanced often, if ever.
These aren't NiMh packs that need to be babysat.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 10-31-2007, 12:53 PM   #610
Moderator
This is very true, just had to mention it for safety precaution..., I still recommend balancing them often.
The 2 SMC lipo packs we got in were both balanced right out of the box.
SMC Racing
Old 10-31-2007, 05:52 PM   #611
PitCrew's Avatar
Just a thought, but did your buddies car have weight added to it so the two cars weighed roughly the same?
I'm sure if a IB4200 weighed what these lipo packs do, people would be completly shocked how they perform. (If the weight wasn't made up for elsewhere on the car)
PitCrew is offline   Reply With Quote
Old 10-31-2007, 09:22 PM   #612
Does anybody know if this Lipo pack will fit into the Corally PHI?
XCELL is offline   Reply With Quote
Old 10-31-2007, 11:26 PM   #613
Tech Legend
Wild Cherry's Avatar
Borrow a Carbon 3200 or a SMC Li-Po & learn what you need to know ....
They are not slow , they are as fast in fact !
Cept they will perform the same even after a hundred cycles....
and
you will save a ton of mola on battery`s ....
Honest ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 12-17-2007, 09:31 AM   #614
Trader Rating: 16 (94%+)
When will SMC get updated information on their website. I hate relying on other websites for sometimes incomplete information.
If you guys would get on top of the SMC and JACO websites, you might be able to increase sales a little more. Information can be the key to a sale, or no-sale.
kn7671 is offline   Reply With Quote
Old 12-17-2007, 03:09 PM   #615
it will be against smc religion to advertise for lipo on their own website,they wont do it till the final breath of the last nimh sub-c cell on planet earth
trackpower is offline   Reply With Quote
Core RC 5000mah Lipos... Nexus Electric On-Road 615 11-05-2008 08:03 AM
SPC 3s 5000mah bobby74 Electric Off-Road 0 06-24-2008 04:18 PM
SMC 28C High Performance 4000mAh - 5000mAh Hardcase Lipos Danny/SMC Electric On-Road 420 04-24-2008 03:36 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
WTB 5000mah lipos (2) and a balance charger vrcoupe R/C Items: Wanted to Buy 0 01-29-2008 09:51 AM
