Old 09-17-2007, 11:49 PM   #1
mafiaracers's Avatar
Trader Rating: 22 (100%+)
Send a message via AIM to mafiaracers Send a message via MSN to mafiaracers
Default Nomadio question
So I got this nomadio "react" in a package deal with a car and some stuff the other day and have a question about the RX. The antenna wire coming out of it is rather large, almost like it has a plastic coating around it and a woven fabric looking thing inside that, almost like an insulator. Does anyone know about these radios or the antenna i'm describing?
Basically my problem is, the antenna wire won't fit into the antenna tube...leaving me scratching my head and an 8 inch wire flopping around and getting in my way.
Any help would be appreciated!
Chris
Chris Woods
MAFIA MOTORSPORTS
http://www.rctech.net/forum/r-c-items-sale-trade/168239-pit-board.html
TEAM WAVE
www.teamwaveonline.com
TQ Racing Wire
www.tqracing.com
mafiaracers is offline   Reply With Quote
Old 09-18-2007, 05:20 AM   #2
ChrisP's Avatar
Contact Scott at Nomadio support
That extra covering is an insulator and I do believe that the antenna wire can be shortened, but I do recommend contact support to verify the specifics on how to do it properly.
Here is the link to the Nomadio contact info:
http://www.nomadio.net/contact.php
ChrisP is online now   Reply With Quote
Old 09-18-2007, 06:57 AM   #3
billjacobs's Avatar
Trader Rating: 55 (100%+)
Default nomadio receiver wire
Use an airplane pushrod tube. Fits perfectly.
billjacobs is offline   Reply With Quote
Old 09-18-2007, 10:20 AM   #4
Scott said to use an RTR antenna tube as they seem to be bigger. Another guy said I could coil it up like a 1/12th car...coil it around the tube and shrink wrap it. All good ideas, i'll check out larger tubes first though. Probably the easiest way.
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 09-18-2007, 11:08 AM   #5
WinnipegRacer's Avatar
Sounds like you have the V2 transceiver. The "weave" that you see is actually a contactor for your coax antenna wire. The antenna wire sits in 2 saddle clips on the IC board within the transceiver case - one clip for the core, and one clip for the weave. Don't be afraid to use a short antenna length under the shell. The radio will still bind.
WinnipegRacer is offline   Reply With Quote
Old 09-18-2007, 11:51 AM   #6
so like...can I roll up the antenna wire and stuff it inside the RX housing? leaving a little pig tail hanging out the back end?
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 09-18-2007, 11:52 AM   #7
vtl1180ny's Avatar
R/C Tech Charter Subscriber
You can coil it up, the actual antenna is just that little piece of wire at the end...
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 09-18-2007, 11:58 AM   #8
does it need to come out of the body at all? or can it all be hidden under the body?
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 09-18-2007, 01:43 PM   #9
vtl1180ny's Avatar
They tell us it should come out of the body but I run mine under without a problem... I've driven my 5th scale a good 900' away without a problem with it under the body...
I still lurk....
Old 09-18-2007, 01:49 PM   #10
well hell, if it's good enough for 5th scale, my 2wbuggy should be fine! Thanks guys!
Chris Woods
MAFIA MOTORSPORTS
TEAM WAVE
TQ Racing Wire
www.tqracing.com
Old 09-19-2007, 05:43 PM   #11
mafiaracers
I have a 1/10 on road electric and all that i do is coil it around the antenna tube and secure it with what ever (tape or rubber band) and lay it under the body shell just make sure it will not get caught on anything.
Steven
Casino Kid is offline   Reply With Quote
w.t.t. nomadio sensor for a nomadio react xtreameracer R/C Items: For Sale/Trade 4 12-07-2007 07:36 PM
Nomadio React Question mattmask Nitro Off-Road 0 10-20-2007 05:40 AM
wtb nomadio thesavagekiller R/C Items: Wanted to Buy 4 02-20-2007 08:15 AM
WTB Nomadio thesavagekiller R/C Items: Wanted to Buy 1 02-16-2007 10:36 AM
Nomadio AzBobby Electric Off-Road 6 02-11-2007 12:21 PM
