Old 10-17-2003, 01:24 PM   #121
sosidge's Avatar
che - thanks for the link, but that's a part of the manual I already have.
Old 10-17-2003, 03:07 PM   #122
Registered User
Hi-LowBrow's Avatar
Send a message via Yahoo to Hi-LowBrow
cHckbOY5>>
I bought this charger from Straight Ink directly and was about $240, actually I paid by Yen.
PizzaDude>>
actually It's almost same as robitronics expert charger, differences are Peak Lock and pulse chargesystem.
RecordBreaker has these function, peaklock system allows you can hold charging when it got miss peakvoltage on the first and 2nd stage.
the pulse charge system makes (it is selectable!!) the batteries more punch!!
Barry White>>
here's a picture and a deta.
sorry, Icould not find spec in English....
Hi-LowBrow is offline   Reply With Quote
Old 10-17-2003, 03:08 PM   #123
Registered User
Hi-LowBrow's Avatar
here's a deta....
Old 10-17-2003, 05:41 PM   #124
sosidge's Avatar
Default Eagle CDC V6.0B vs Pro-Trak
As promised, here are some (pretty meaningless) comparisons between charging on the CDC and Pro-Trak...
This is using a tired pack of GP3300's (yes I know the capacity stinks)...
First of all, a cycle was done on the CDC to "wake the cells", being their first cycle for 3 or 4 days.
Second cylce was on the CDC (again). Settings were 5A chg, 20A dischg, 5mV per cell delta.
Charging from flat (4.8v discharge on 1st cycle)...
Capacity in - 2970
Peak Voltage - 9.410 (my eagle seems to rate charge voltages 0.1v higher than my multimeter)
Discharge to 4.8v (CDC default) after brief pause (no more than 2 minutes)...
Capacity out - 2612
Av voltage - 6.916 (my cdc seems to rate discharge voltages 0.1v lower than my multimeter)
After an hours cooling, third cycle was on Pro-trak, identical settings as CDC (peak delta 0.03v, same as 5mV per cell).
Charging from flat...
Capacity in - 3002
Peak Voltage - 9.19 (pro-traks voltage ratings are with a few hundreds of a volt of my multimeter)
Discharge to 4.8v after brief pause...
Capacity out - 2716
Av voltage - 6.88 (this has been calculated by myself by from the Pro-trak Av1 and Av2)
So there you go - on the surface, the Pro-Trak appears to get more capacity from the cell, but with poorer voltage. But because of the inconsistencies in voltage monitoring between the two and my multimeter, I wouldn't like to say anything for sure! Next test is on the track...
Old 10-17-2003, 05:55 PM   #125
tmunno's Avatar
R/C Tech Charter Subscriber
Best chargers: We own (1) Turbo 35 (1 )turbo 35 BL and (2) Novack Millinium Pros. Also have 1 Turbo 30 for sale,its an older one (not flex) but it is in excellent condition.
Tony Munno
Munnograffix
CFX Paintworks,
tmunno is offline   Reply With Quote
Old 10-17-2003, 05:56 PM   #126
It is indeed meaningless.
elnitro is offline   Reply With Quote
Old 10-18-2003, 01:15 AM   #127
PizzaDude's Avatar
[QUOTE]PizzaDude>>
the pulse charge system makes (it is selectable!!) the batteries more punch!! [QUOTE]
Well, these are the issues I had with my Expert.
Not being able to self select peaksetings in the 3stage mode.
And the pulse-charging is what seems to give the Pulsar it's little extra...
PizzaDude is offline   Reply With Quote
Old 10-18-2003, 03:04 AM   #128
cHckbOY5's Avatar
Send a message via AIM to cHckbOY5
any of you guys use the new yokomo charger?... seems pretty good
cHckbOY5 is offline   Reply With Quote
Old 10-18-2003, 12:13 PM   #129
Regional Moderator
disaster999's Avatar
i use it and its really good! i used the yokomo charge for a race and it does produce a lot more punch than regular peak charge!
disaster999 is offline   Reply With Quote
Old 10-19-2003, 07:48 PM   #130
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
which one do you have disaster, I was looking at these earlier, look like some nice chargers
BHenderson is offline   Reply With Quote
Old 10-20-2003, 01:10 PM   #131
I love my CE GFX.
NismoSkyline17 is offline   Reply With Quote
Old 10-20-2003, 01:37 PM   #132
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
Hi-LowBrow, Do you know where to get the instructions for the Record Breaker in english?
BigDogRacing is offline   Reply With Quote
Old 10-20-2003, 01:56 PM   #133
rtypec's Avatar
Talking Best Charger of All-Time
rtypec is offline   Reply With Quote
Old 10-20-2003, 04:05 PM   #134
JohnA's Avatar
Default Re: Eagle CDC V6.0/B
Double post...
JohnA is offline   Reply With Quote
Old 10-20-2003, 04:11 PM   #135
JohnA's Avatar
Originally posted by sosidge
Question for anybody with this particular charger (or it's Integy equivalent)...
Is it normal for the charge cycle to stop for a couple of seconds every minute - it's rather freaking me out - I'm guessing it's part of the "Internal Resistance" monitoring or some other calculation - either that or mine is faulty...
Also, there is a manual addenda in the box (all in Japanese sadly) - the diagrams show suggested thresholds for GP and Sanyo 3300's, and also mentions "Batt V Too Low" and "Batt V Too High", plus a table of amperages - does anyone know what this all means and is it important?
PS I'm trying to do some back to back tests with the Pro-trak to see how the two compare...
The pause is normal, mine does it too so do others I've seen. Not sure exactly why it does it but it does!
The "Batt V Too Low" and "Batt V Too High are error messages you get when it detects too few or too many cells connected, dont worry.
RE Your Pro-Trak / CDC comparison. It would be interesting to see the same pack charged on one and discharged on the other and vice-versa. I'm sure you have something better to do though
no time, must go gabbyb3 R/C Items: For Sale/Trade 2 06-03-2006 08:23 PM
MRC 959 charger, Trinity Real Time 2 discharge tray...... SMcpot R/C Items: For Sale/Trade 8 12-21-2005 09:03 AM
Time for a new charger! Roberto Falcon Electric On-Road 3 01-16-2005 07:40 PM
Big Time JayBee Electric On-Road 0 06-23-2004 09:40 PM
run time VS tweak time bigbutstupid Electric On-Road 7 06-16-2002 04:40 PM
