Old 09-14-2007, 08:10 AM   #1
bigemike's Avatar
Trader Rating: 35 (100%+)
Send a message via Yahoo to bigemike
Default tc5 with orion 4800 Need Help
I need a picture of how you guys are mounting the orion 4800 in the tc5. I looked at it yeasterday, and it looked like the factory side rails won't fit with lipo pack. I could just see the pack sliding out if I only taped it in or only used the supplied bar. Any pictures would be great. If you can't post them here, email them to [email protected]
Thanks a bunch.
bigemike is offline   Reply With Quote
Old 09-14-2007, 08:16 AM   #2
STLNLST's Avatar
Trader Rating: 21 (100%+)
I'll post pics of mine after Saturday. I did remove the side rails in order for the pack to fit and you have to shift the pack over to the center of the chassis some in order to fit the pos and neg plugs into the battery (the top deck is in the way)
STLNLST is offline   Reply With Quote
Old 09-14-2007, 01:02 PM   #3
sonic31's Avatar
cut out two strips of lexan exact size as the battery slots and double side tape it to the bottom of the lipo pack and if you want strap it down or use the battery hold that came with the kit it works perfect no problems period.
sonic31 is offline   Reply With Quote
Old 09-14-2007, 01:05 PM   #4
overflow's Avatar
I do the same thing, but I use carbon strips and glue. I use the battery strap and it works well. Just be prepared to add a bunch of weight to that side of the car.
overflow is offline   Reply With Quote
Old 09-14-2007, 01:44 PM   #5
bigemike's Avatar
where do you guys add the weight. I am thinking about making a 4 scale tweak station. I need to read up on it first though, but I have seen the oval guys use them, so I have a pretty good idea of what I need to make. Anyways thanks for the help, the spacers to fit in the slot are an excellent idea. I appreciate it.
Old 09-14-2007, 01:50 PM   #6
wannabee's Avatar
Wrong thread, but I'm too lazy to look! lol
Can you guys post your charging recipe?
I'm using an Integy 16x8v6.
Thanks in advance!
wannabee is offline   Reply With Quote
Old 09-14-2007, 07:51 PM   #7
Rommel's Avatar
I used one of these:
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LX2778
mount towards front of car and make two holes in chassis to secure.
Rommel is offline   Reply With Quote
Old 09-14-2007, 11:59 PM   #8
bigemike's Avatar
I made these tonight, worked great. Very secure. Thanks a bunch.
Old 09-17-2007, 07:17 PM   #9
Default 4800 in TC5
I use the 4800 lipo tray from the Losi Jrxstype R. cut off the two outside mounting tabs and bolt it thru the chassis under the belt (you gotta drill two holes). I soldered a short 90 degree adapter together and plug it into the inside battery connector so it can plug up out from under the top deck. Hold down with the stock Assoc. battery strap.
Tray is very cheap.
Holds battery securely. (No problems in 10-15 race days.)
Quick change (you can switch back to round packs between heats easily.)
Allows mounting far to the outside, requireing less weight. (I tape lead stick on weight to the outside edge of the battery.)
Try it you may like it!!
Ned
aarcobra is offline   Reply With Quote
Old 09-17-2007, 07:49 PM   #10
PitNamedGordie's Avatar
Send a message via AIM to PitNamedGordie Send a message via Yahoo to PitNamedGordie
Tray is very cheap.
Ned
I'd like to see some pics if you have them...
☆ The Track @ Harbor Hobbies ☆ www.harbor-hobby.net ☆
PitNamedGordie is offline   Reply With Quote
Old 09-17-2007, 10:33 PM   #11
Roads's Avatar
Thanks in advance!
Correct, this is the wrong thread.
Team Associated TC5 - Teambr00d CO27, Futaba S9550, Novak Rooster, DSM
Last edited by Roads; 09-17-2007 at 10:35 PM. Reason: I'm an idiot who can't spell
Roads is offline   Reply With Quote
Old 09-18-2007, 12:41 AM   #12
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Thanks in advance!
as above wrong thread . but also this thread is talking Li-Po & tc5
hope your not using the 16x8.. for li-po charging
if not
thats okay
battery thread in company section will do
back on topic
so you guy's are cutting up your brand new car to fit 4800
does this the car manu do not see li-po being used in the near future ..
does the 3200 carbon fit with no prob's ??
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 09-18-2007, 12:53 AM   #13
B4Bandit's Avatar
I don't quite understand the wording of this. Can you please supply pics?
Cheers.
B4Bandit is offline   Reply With Quote
Old 09-18-2007, 05:45 AM   #14
bigemike's Avatar
I will try to post some pics tonight. Basically we cut pieces of lexan, the same size as the slot in the bottom of the cassis, and we use double sided tape to stick them to the bottom of the chassis. Then you tape in the battery. Nothing on the car gets modified. We are just adding the spacers to the bottom of the pack, so they fit down in the cassis and keep it from moving.l
Old 09-22-2007, 12:34 PM   #15
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
Any pics yet? I am also very interested, as I will be running BL and Lipo in my TC5.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Orion 3.5, 2 Orion 4800 Lipos, RP36 tires! act2007 R/C Items: For Sale/Trade 21 08-30-2008 11:51 PM
Spektrum SR3000 RX, Orion 4800 Lipo, Orion 13.5 BL Jake S R/C Items: For Sale/Trade 40 07-06-2008 06:47 PM
Orion 4800 dodgeguy R/C Items: For Sale/Trade 3 03-10-2008 12:44 PM
Orion 4800 nickclark30171 R/C Items: For Sale/Trade 4 02-28-2008 03:54 PM
4800 LiPo Peak Racing, 2 packs like new (Orion 4800) ALJR R/C Items: For Sale/Trade 14 01-09-2007 09:37 PM
