Old 09-14-2007, 07:39 AM   #1
Send a message via AIM to jsl6v8
Default what to look for in a power supply
Well I've decided that I should probably get a DC power supply but I don't really now what to be looking for, as far as how many amps or watts it can push out. I know that I want something thats 12volt DC power and that I can plug into my house current beyond that I'm lost. And why can't I use a computer power supply, they run the right current and have high amp capacitys.
jsl6v8 is offline   Reply With Quote
Old 09-14-2007, 07:47 AM   #2
Uga
Uga's Avatar
You can use a PC power supply, that's the cheapest option. Here are links how to tweak your PC PSU to use it with your charger:
http://www.marcee.org/Articles/PCPowerSupply.htm
http://web2.murraystate.edu/andy.bat...owersupply.htm
Uga is offline   Reply With Quote
Old 09-14-2007, 07:48 AM   #3
trjracing's Avatar
Hobbico model 930 power supply is the one I use for my triton charger it works great for me at home and it has the proper outputs for 3amps and 11.5amps. Check it out.
GOD IS GOOD, LIFE IS GOOD... I AM THE BAD BREED... B.B.R. BADBREEDRACING... Rest In Peace Marshall G. Winston America's Hobby Center, You will be missed...
trjracing is offline   Reply With Quote
Old 09-14-2007, 07:59 AM   #4
well I've found a CPU power supply thats up to 20 amps, am I correct in assuming that that would pretty much power anything I need to supply power too? also whats a good power splitter, I guess a power bar or something to plug all my electronics into it.
Old 09-14-2007, 08:06 AM   #5
Uga
Uga's Avatar
This should do -> http://shopping.rcmodel.hk/product_i...oducts_id=5050
I think you can find them almost in any HS. But if you are going to make the PSU yourself, I think you can also make something up for splitting and save a few bucks
To hold just 1 charger, 300W PSU will be more than enough, if you have 2 chargers, 400W should be fine. Look at the brands, I would recommend FSP or HEC, imho the best quality/price comparsion.
Old 09-14-2007, 01:57 PM   #6
Regional Moderator
CarbonJoe's Avatar
Actually, running 2 chargers charging at 6 Amps (assuming that the PS is actually supplying 13.8V), that is only 165 Watts. A 300W PS is more than enough. I use the Radio Shack 15 Amp PS (13.8V * 15 A = 207 Watts), and I can charge 2 packs @ 6 A each using 2 Duratrax ICE chargers, as well as powering my MuchMore CTX-D without breaking a sweat.
CarbonJoe is offline   Reply With Quote
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
turning pc power supply into a rc power supply andy_666 Electric On-Road 20 01-16-2006 05:20 PM
SEC Power Supply vs. Hobbico Power Supply? F1Junkie Electric On-Road 1 06-05-2004 08:52 AM
