Old 09-13-2007, 05:55 PM   #1
Big Daddy Cool's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to Big Daddy Cool
Default ICE Jog Dial and Buttons
Hi, my ICE's jog dial and left/back (yellow) button is working erratically now. Has anyone encountered this problem? What course of action was taken? Does anyone know where I can order replacement parts for these? I do not want to send it back to Duratrax for repairs as shipping will be quite expensive coming from the Philippines. Thanks.
Big Daddy Cool is offline   Reply With Quote
Old 09-13-2007, 07:47 PM   #2
Centerline Racing's Avatar
Trader Rating: 33 (100%+)
Mangandang Gabi...
I had the same problem with an MRC Superbrain 969 Charger. The button contacts are most likely dirty.
Mine was out of warranty so this is what I did:
I disassembled the unit,
Sprayed the affected areas (buttons) with a good quality electric motor cleaner,
Used low power compressed air to 'flash off' the cleaner,
Reassembled.
This worked until I sold it 6 months later, I haven't heard of the buttons going bad again from the guy who bought it, over a year now.
Be sure that you make sure that all of the spray cleaner is evaporated and dried before you energize the unit.
Regards,
Allan
Centerline Racing is offline   Reply With Quote
Old 09-13-2007, 08:00 PM   #3
Trader Rating: 69 (100%+)
bdc: also found this from the ice thread ...
Originally Posted by howard1
There is a way to fix the yellow button problem. You will have to open the case first. On the buttons you will see 4 black dots on each corner. Carefully cut these off with a hobby knife and lift the shaft off. You will see the contact plates have some corrosion on them. Take some fine grit paper and clean off. Re-assemble and use a drop of shoe glue over each of the corner spots to keep the switch together allow to dry and test first before assembling the charger. Be careful when working with an opened charger as there is current in the circuitry!
looks like your dirt found its way into your ice because of all the offroading
marvi is offline   Reply With Quote
Old 09-14-2007, 02:23 AM   #4
air8's Avatar
Sometimes I have to hold the yellows for a few extra moments or I have to push on the extreme left side of the buttons. I haven't had them stop yet, but it takes some finess.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-14-2007, 07:12 AM   #5
Thanks guys. I'll open it up and see how the contacts are affected. It still actually works fine but when it acts up, it can be annoying.
marvi: The dust from sonic and QCRCCCC could have gotten in. Off road rocks though and is a welcome change after nearly 10 years of on-road rc.
2-Nova or RB standard buttons...25.00 shipped MercyRev R/C Items: For Sale/Trade 17 09-08-2008 08:17 PM
2 Like New Nova or RB Buttons 30.00 shipped MercyRev R/C Items: For Sale/Trade 10 07-28-2008 05:11 AM
Buttons Heads PROVK Nitro On-Road 3 06-20-2008 05:31 PM
max SL3 and nova 12SCT head buttons TomB Onroad Nitro Engine Zone 9 01-17-2008 05:29 AM
m11 buttons? aus jd 2703 Electric On-Road 0 06-17-2007 03:48 AM
