XBR and GTB: What are the differences?
I want to upgrade the ESC in my 05R. I know that sometime in the near future I will probably be racing with brushless motors and Lipo batteries, so I need a speed control that will handle them. I like to stick with Novak because i have had good experiences with them in the past, so that's why I'm looking into the XBR and GTB. I know they are about $50 apart in price, but what are the things that set them apart that an club racer would notice? I know the GTB has lower on resistance and a cooling fan already installed, but what are the real differences that affect performance? thanks for your input
The GTB handles the hotter motors (3.5 woo hoo) where the XBR goes to 8.5. The XBR handles 7 cells where the GTB only does 6. GTB for racers, the best choice IMO. The punch and efficiency coupled with the ability to handle the hotter motors gives it the edge. Now, if you want to bash, the 7 cell XBR is good enough.
u might want to think about resale value too, should u decide to sell it in the future.
I reckon it will be much easier to sell the GTB simply bcos it can cater to all racing classes (mod->stock) while the XBR can’t.
One pretty handy deal about the XBR is that it fits into a few cars easier than the GTB. The GTB is a more race-oriented part, but the XBR is pretty decent...especially if you can find one cheap. It does pretty much everything the GTB does, aside from the lower-wind motors...even lipo cut-off.
BTW -- I have two GTBs and one XBR.
if you are not yet running brushless, I believe the XBR is easier to use w/ Brushed motors also...(easier setup)
Super Moderator
i thought that they both have the same profiles you can select from? also, i have pretty limited space in my 05R for a speed control. not saying i couldn't move the receiver around, but the smaller one would definately be a plus. also, does the cooling fan make a difference if i would be primarily running brushed motors? i figure that a 19 turn brushed motor would not stress the ESC that much, so there is no need for a fan until i go to a lower wind brushed or brushless motor...is this assumption correct?
I had to raise the XBR about 1/4" with a little block so that it would fit in my 05R.
What about the FAN thing guys ?, do the FAN make a lot of difference ?, im about to start racing electrics after years of nitro sedan and nitro 1/8 offroad racing and im a little tight on budget, this will be raced on 19T class, non-lipo batts and maybe brushless 10.5 motor.
thanks,
thanks,
thanks,
thanks,
thanks,
thanks,
