Virtual RC controller Calibration >
Old 09-13-2007, 03:57 AM
magm20001's Avatar
Default Virtual RC controller Calibration
Hi i dont uderstand the steps to calibrate my Helios the VRC USB hub
Step 1: Leave Handle centre and press button on the controller
does this means Dont move the wheel and pull full throttle and release?
Step 2: Move Handle in complete circle and press button on the controller
does this Mean Turn wheel full lock left and right then full thottle and release?
Step 3: Leave Handle centre and press button on the controller
does this Means Dont move the wheel and pull full throttle and release?
Step 4: Move the Z-axis all the way up and then all the way down and press button on the controller
what does that mean??? z-axis??
and does "button on controller" refer to the throttle?
any help appreciated??
magm20001 is offline
Old 09-13-2007, 04:21 AM
Simon M's Avatar
When you selected device did you select
VRC-2 USB adapter
Simon M is offline
Old 09-13-2007, 04:29 AM
magm20001's Avatar
VRC-2 USB adapter
no i didnt, now i have
your a legend
Old 09-13-2007, 04:32 AM
Not sure where you got them steps from?
If your using the USB adapter then its quite straight forward.
Fire up the game, select usb2 adapter have everything on your radio centred etc, you can use the calibrate button to check all your axis work properly and then just race. I didnt follow any steps like you listed the last time I did it anyway.
But the advice i will give you is you'll have better look asking in the right place, the VRC forum or virtualrcchat.info can be quite good. i'm not sure how many VRC users hang around this place but the above two place are all 100% vrc users so seems like a better idea to get help there.
8800 is offline
Old 09-13-2007, 04:28 PM
Super Moderator
Grizzbob's Avatar
The steps he got are directly from Windows' Game Controller Properties tab(I know because I have the VRC pistol-grip controller, had to go through this to calibrate it for any games). In any games aside from VRC, you'd need to calibrate it in Windows or else it won't work at all. Unfortunately, though, there seems to be some serious limits as far as which games support it well enough to use(works ok for TOCA Race Driver 3, but I can't get it work at ALL in Need For Speed Carbon, I suspect that it's hit & miss for most games)....
Grizzbob is offline
Old 09-13-2007, 05:01 PM
magm20001's Avatar
anyone know if the USB connector work with "Colin McRea Dirt" ??
