Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 02-03-2008, 06:44 PM
  #1231
JimmyMac's Avatar
Here ya go. 3Racing TA05IFS chub on my 416.
JimmyMac is offline
Old 02-03-2008, 07:09 PM
  #1232
Vicko's Avatar
Trader Rating: 14 (100%+)
yo mac how long have u been running them, do they bent easy?
I got 2 sets myself both have not but them on yets
Vicko is offline
Old 02-03-2008, 07:14 PM
  #1233
Fastforward's Avatar
Default alum c-hubs
Thanks JimmyMac and Vicko!! You have just put the joy back in on road racing.
Fastforward is offline
Old 02-03-2008, 07:22 PM
  #1234
JimmyMac's Avatar
Well today was the first time I've run them. Only real incident I had today was hitting a corner dot during practice and cartwheeling down the straight and almost into the highway (smooth parking lot track). So I can't comment too much on durability. I know other things will break now if I do clip a corner. But I'm willing to deal with it. Chubs suck because they arent' interchangeable left to right. But arms and spindles are. Anyways, so far so good.
JimmyMac is offline
Old 02-03-2008, 10:35 PM
  #1235
RC MARKET's Avatar
RC MARKET is offline
Old 02-04-2008, 12:05 AM
  #1236
JimmyMac's Avatar
Hi RCMarket, this is kilruf/mike mc. I've been ordering alot from ya lately. Do you know when the 416 spool will arrive? I currently use the 415 spool. But I find it may off center itself at times. But only very slightly. Also, how do I check back orders from your website? Or how do I change them? Email me if you can at [email protected] Thanks...
JimmyMac is offline
Old 02-04-2008, 08:25 AM
  #1237
mac853's Avatar
Originally Posted by azhar
mac853....
i got this info from tamiya america.....
Oh yeah, there is!
Thanks for your reply.
In my opinion they should release also alluminium wheel axle and 44mm steel drive shaft, as i remember in last year, a lot of 415 guy broke front blue shaft in races.
mac853 is offline
Old 02-04-2008, 09:30 AM
  #1238
Trader Rating: 51 (100%+)
I just installed my 3Racing c-hubs yesterday too. They fit nice. I used about 1.2mm of shims instead of the 1mm shim in the instructions. Can't wait to give the car a try with the short arms!!
Apex is offline
Old 02-04-2008, 09:48 AM
  #1239
RC MARKET's Avatar
Check pm
we system was posted no stock ,
but too many customer order again with me ,
so had this backorder case !!
we was order again , next lot around 20th arrive !
Sorry !
Old 02-04-2008, 12:30 PM
  #1240
JimmyMac's Avatar
They came with instructions??? haha. I think one side I have shimmed 1.1mm and the other side is just 1mm.
RCMarket, thanks for the reply. I'm going to go back and look through my records. I'll email you if I find anything out. Thanks again for the quick reply.
JimmyMac is offline
Old 02-04-2008, 12:46 PM
  #1241
I meant the original 416 instructions say to put in a 1mm shim.
Apex is offline
Old 02-04-2008, 01:09 PM
  #1242
RC MARKET's Avatar
please pm to me your order no. ?
Thanks!
Old 02-04-2008, 01:36 PM
  #1243
CanyonCarverR1's Avatar
Can someone tell me how the 416 kit shock oil compares to Mugen shock oil?
CanyonCarverR1 is offline
Old 02-04-2008, 01:42 PM
  #1244
Racing4Evo's Avatar
Tamiya Yellow is 400 oil.
Racing4Evo is offline
Old 02-04-2008, 07:05 PM
  #1245
Blueman Austria's Avatar
Originally Posted by TryHard
Nope, a standard D block can't be flipped... but the ones included with the 416 can be (they are the same as the X-series).
The D-Bridges don't fit...
Got back from a good day's racing today, running 10.5 indoors. Pretty much Victors setup from the DHI, apart from a couple of extra changes to try and get some more steering (45wt rear oil, 2.5mm inner shims under the rear link, rear shocks in hole 4, 1mm rear axle spacer). Car was very good at the start of the day, but as the traction came up I was struggling to get the front end tucked in tight. This may have more to do with my limited experience of having to drive with a bit of brake (the track was pretty tight...), than any inherent setup deficite, but I have a few things to try next time out.
I think some softer shock oil all round (45/40), and maybe a stiffer rear roll bar or less rear toe-in may help to free the car up when the grip comes up.
Having said that, car was very safe and easy to drive.... and the extra grunt of the 10.5 over a 27t was much more enjoyable Only broke one part all day...suprisingly, it was a C-hub, and didn't realise for a bit, opps!! :smile
Plus I was happily faster with the 416 versus my old 415 (admitdly in the hands of another driver)... although a large amount of that deficite is probably down to him still running a 1-way, where I'm certain a spool is faster.
Overall though, probably had the most fun at a meeting for a long time :... and now back to stock () for the next round of Carpet wars...improvements to the setup for stock to be tested then
Regards
Ed
P.S. Setups attached... plus an improved blank sheet
Hy Ed!
I want to know how the Damperrebound (the thing that Jilles posted), the 25% you have in your sheet, is noticable?
And whats then a good basic for tarmac?, 50-75% ??
Thanks in advance, blueman
Blueman Austria is offline
