Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 01-14-2008, 01:50 AM
  #1006
TryHard's Avatar
Originally Posted by Anders Myrberg
It does. But it also say these drivers are quite good
quite good? All four (including Hupo) are bloody awesome!
Very strong team for TRF europe
TryHard is offline
Old 01-14-2008, 11:20 AM
  #1007
habis's Avatar
TRF Team 416 cars from this weekends DHI cup
Marc drove with the short arms in a DD,XA,E set up with 3mm chamber shims.
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-victor.jpg   Tamiya TRF416 / TRF416WE / TRF416X-gilles.jpg   Tamiya TRF416 / TRF416WE / TRF416X-marc.jpg
habis is offline
Old 01-14-2008, 11:33 AM
  #1008
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by syndr0me
It's encouraging to see the top drivers do so well with the 416. I'm looking forward to seeing their setups from the race, and what kinds of things they're doing. I've been running my 416 like crazy with CS27's on the rug, and feel like it's getting pretty close. I absolutely adore this car, it's by far my favorite sedan I've owned.
What? No more Type R for you? What's so nice about the TRF416 that you like it more than a Type R? Where are you getting parts from?
yyhayyim is offline
Old 01-14-2008, 11:37 AM
  #1009
bigbutstupid's Avatar
bloody good looking cars, if only my car is still in such pristine condition..
anyway, for the center pully, there seems to be some play as well, should it have some play or should i shim it up? i tried shimming it up and theres no binding, doesnt hurt lap time, but i wonder if theres any bad side effects to the car's wear and tear.
bigbutstupid is offline
Old 01-14-2008, 12:30 PM
  #1010
syndr0me's Avatar
Trader Rating: 32 (100%+)
The Type-R is a fine car, but I've come to the conclusion that its style of handling is not for me. I'm able to be fast with it, but can't find any consistency at all. Also, I've pretty much abandoned foam tire racing, and wanted a car with a true pedigree in rubber tire. I'll probably have my R's up for sale in a week or two. :-(
As for parts, they've been a little scarce in the US still. It looks like Tower, AmpDraw, Speedtech and TamiyaUSA will be options in the future. There's a few overseas shops that ship to the US VERY fast if you're in a real bind for parts, but it's a little pricey. They can ship slow for reasonable prices as well.
syndr0me is offline
Old 01-14-2008, 12:58 PM
  #1011
C van der Hagen's Avatar
Originally Posted by C van der Hagen
3,5 BL set-up, 5 cell, rubber tyres
Also seems to work in Denmark
C van der Hagen is offline
Old 01-14-2008, 01:37 PM
  #1012
RC MARKET's Avatar
5 cell ?
RC MARKET is offline
Old 01-14-2008, 01:44 PM
  #1013
habis's Avatar
Originally Posted by RC MARKET
5 cell ?
Yes, 5 Cells
marcīs car....not with the usual paint
Attached Thumbnails Tamiya TRF416 / TRF416WE / TRF416X-marc-car.jpg
habis is offline
Old 01-14-2008, 02:16 PM
  #1014
Default re
Hey guys, i have been testing a few things and have come up with some good results. I will be posting a setup asap.
As for bushings in your shocks i have tried almost everything. People at my local track refer to me as the "shock guy" lol. I found the bushings tend to make the car respond too quickly making the car difficult to drive. One thing i have always done is run 100-75% rebound but i control the speed of the piston using muchmore shock o-rings, they come in 30-50 degree ratings. I rarely use anything on top of the diaphram but if i do i use muchmore foam inserts which come in different thicknesses. So for tighter tracks with shicanes i would use full rebound and higher piston speed and for longer more flowing tracks i would use between 100-75% rebound but with a slower piston speed. Hope this makes sense to you guys.
Heres a shock tip(tamiya only):
when installing the pistons onto the piston shafts place a .2mm spacer under the piston to take out any slop. Also i like to trader out the lower plastic bushing(not the guide piece) for a 2nd o-ring. When you do this the shock will be a little more consistent and you can really fine tune piston speed with this setup.
I prefer Muchmore Perfect Silicone O-ring 40deg using muchmores shock slime.
TRFwhitey is offline
Old 01-14-2008, 02:20 PM
  #1015
Default re
Almost forgot....
CONGRATS to victor for yet another win for the 416. Great showing from all the TRF guys!
Old 01-14-2008, 02:23 PM
  #1016
syndr0me's Avatar
Hey Corey, did you come up with anything reasonable for foam tires at Novak?
syndr0me is offline
Old 01-14-2008, 02:33 PM
  #1017
Default re
Ya i did before i had to retire the 416 because of a split custom upper deck. It felt pretty promising but i could not wait for it to be repaired so had to go back to the old car. The old car tweaked way to ez which ruined many of my runs. The main thing i had to overcome with the 416 on foam was the weight in the rear. The excess weight in the rear of the car made the car over rotate entry/mid corner...it was a handful! I was able to move my esc forward about 6mm and installed a larger spur to move the motor forward as well. This made the car very balanced and above all, much easier to drive! I will post my foam setup along with the rubber one i have been workin on as soon as i can!
Old 01-14-2008, 02:41 PM
  #1018
Trader Rating: 50 (100%+)
Yes, 5 Cells
Is that a Mazda 6?
Apex is offline
Old 01-14-2008, 03:25 PM
  #1019
108T 64 dp spur fits the 416
Old 01-14-2008, 03:30 PM
  #1020
Default re
thats what i used
