Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 11-15-2010, 01:39 PM
  #10051
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Geppetto
Thanks Mike. I'll take a look at the AE site. Hopefully, they provide published specifications for their springs.
Maybe someone else can address the importance of spring length???
+1 to what Johnny said, other than that, you just need an appropriate spring length for the application, ie, too long of a spring wont let you set ride height, etc.
AE will tell you spring rate, but that is it. A pair of their springs is only $3 or $5, so its worth a shot Its something ive always wanted to try at the C, I just dont get to run there often enough (or remember to get the springs to try )
geeunit1014 is offline
Old 11-15-2010, 02:41 PM
  #10052
Trader Rating: 35 (100%+)
Originally Posted by Johnny Wishbone
If you have 2 springs rated the same but different lengths they should function the same, as long as the short spring does not compress so much that you run into coil bind issues. (The spring is so compressed that the coils touch and no longer allow for any compression.) Hope thats the answer you where looking for.
Thanks JW. Makes sense.
Geppetto is offline
Old 11-15-2010, 03:34 PM
  #10053
I did a search on this thread looking for information regarding springs (over 20 pages), but I still need help (with springs ).
Questions:
1.) other than Tamiya, which manufacturers springs are a direct fit to my 416x shocks?
2.)I see suggestions referencing 19.5 spring stiffness, but I don't know which springs fit and have that stiffness.
3.)Is spring length important?
Tamiya has Red, Yellow, Blue, and White springs and they are available in "short" and a standard length??? Tamiya has a white spring set with red, yellow, and blue dot indicators. Tamiya has a black set with red, yellow, and blue dot indicators. Tamiya has a milky blue set with red, yellow and blue dot indicators. Are these all basically the same just in different colors?
Is there any advantage to using a short spring over a long spring?
Maybe we just need a tool for measuring spring stiffness.
HB/hpi springs should fit
M3dreamin2008 is offline
Old 11-15-2010, 11:08 PM
  #10054
Toh WL's Avatar
for example the tamiya white spring set has color dot obviously on the top & bottom. the setback is the paint can get peel off under normal operations. hence then u need to judge yourself on the stiffness. maybe can count the coils to remember which is which.
personally i prefer the older type with full color...
Toh WL is offline
Old 11-15-2010, 11:25 PM
  #10055
crabboy's Avatar
Trader Rating: 58 (98%+)
Yeah all the guys I run with use HPI springs also the Hara progressive springs also work good.
Rhys
crabboy is offline
Old 11-16-2010, 01:45 AM
  #10056
CraigM's Avatar
Trader Rating: 34 (100%+)
Rhys
The HPI springs work better with the roche retainers
CraigM is offline
Old 11-16-2010, 06:51 AM
  #10057
artwork's Avatar
Trader Rating: 88 (100%+)
On the Tamiya the Tamiya and HB springs work best. The HB springs tend to be a bit more linear then both the Tamiya and Hara spring sets. I would steer clear of the AE springs...they tend to be really inconsistent from spring to spring.
I prefer the HB springs on both carpet and asphalt.
artwork is offline
Old 11-16-2010, 09:23 AM
  #10058
Thanks guys for all of your follow-up responses on the subject of Springs.
Geppetto is offline
Old 11-17-2010, 11:48 AM
  #10059
Mugen10's Avatar
3rd time post so I guess know one knows the ball bearing size that is used on the diff. outdrives for the 416X.
I know the part number for the tamiya # is 42115 but in the states it is hard to find without ordering.
Mugen10 is offline
Old 11-17-2010, 11:59 AM
  #10060
M-Technic's Avatar
Trader Rating: 15 (100%+)
10mm inner diameter
15mm outer diameter
M-Technic is offline
Old 11-17-2010, 12:59 PM
  #10061
jackdani's Avatar
hi guys,
just posting here to have some advice...
i m wondering to change my mi4lp race version, which actually is the cheap one, with some good stuff as i started racing at my local track.
tought to go with the upcoming tc6, but now i m really considering even the trf 416...as i have the possibility to purchase it at a very good price.
i'm not sure about this decision, i would like to hear from you who have it, how the car goes and how good is built!
i dont have any information because here in italy this chassis is not so diffused, considering that 90% is xray...
furthermore i dont care about the trf417, becasue it would cost too muchanyway, and i was thinking how the lipo chassis for 416 goes!
if you all can give me a little advice i would br vary thankfull!!
jackdani is offline
Old 11-17-2010, 01:04 PM
  #10062
Mugen10's Avatar
Originally Posted by M-Technic
10mm inner diameter
15mm outer diameter
Big Thaks!
Mugen10 is offline
Old 11-18-2010, 12:56 AM
  #10063
Originally Posted by jackdani
hi guys,
Having recently changed from a TC5r to the 416x and buying the Tamiya lipo chassis upgrade all I can say is ITS AWESOME!!!!!!!!!! I shaved over a second off my lap times at my local track running 13.5/2.1 prostock Sp running the kit setup in the car. Only thing I changed was going to the HPI PRO4 springs, which is what most of the team drivers run, to pink fronts and silver rears on (low grip) outdoor ashphalt. The build was very good especially compared to the TC5 and the quality was exactly what you would expect (much higher) after spending alot more than other tc's on the market. Realisticly you dont need the 417 as the 416x with lipo chassis upgrade is pretty much a 417 short of a few more refinements.
Bumpy is offline
Old 11-18-2010, 01:03 AM
  #10064
jackdani's Avatar
thanks very much, your experience is quiete similar to mine, i m running 13.5/2.1 sp too!
this is the one i shold buy...think it s not the "X" version right?
http://www.dmmodel.it/automodelli/au...amiya-416.html
do you think will worth the money, mayby with some upgrade, or it is too old?
and which is the lipo chassis, do you have a link?
thnaks very much
jackdani is offline
Old 11-18-2010, 07:08 AM
  #10065
PitNamedGordie's Avatar
Has anyone tried these? For $21.50 they may be worth a try if they work.
http://store.hkshobby.com/product_in...oducts_id=8273
PitNamedGordie is offline
