Tamiya TRF416 / TRF416WE / TRF416X >
Like Tree4Likes
Old 11-13-2010, 11:58 PM
  #10036
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Thanks sir found the setup through the search button
Ultraspeed84 is offline
Old 11-14-2010, 06:35 AM
  #10037
Mugen10's Avatar
Does anyone know the size of the diff. bearings for the outdrives?
The bearings seems pretty close to most cars outdrives.
Mugen10 is offline
Old 11-14-2010, 10:30 AM
  #10038
geeunit1014's Avatar
Trader Rating: 14 (100%+)
Originally Posted by M3dreamin2008
Thanks Gee. I will be running at the C next weekend. Maybe i could use this but slightly stiffer?
If your running at the C, I would start with this one. What you need to do at the C to make a car work is very different than anywhere else, you cant be afraid to try funky things, like running more camber F than R, dropping a lot of rear toe, etc. This worked pretty good, but has a bit of push to it. I would also want to try stiffer springs, like a 19lb aftermarket front, and white rear.
File Type: pdf
geeunit1014 is offline
Old 11-14-2010, 04:32 PM
  #10039
badboy's Avatar
Default 416x lip chassis?
hi.
will the 416x lipo conversion chassis fit the 416we?
thanks.
badboy is offline
Old 11-14-2010, 05:09 PM
  #10040
artwork's Avatar
Trader Rating: 88 (100%+)
Originally Posted by badboy
hi.
thanks.
yes but the new top deck does not work on the WE.
artwork is offline
Old 11-14-2010, 11:17 PM
  #10041
badboy's Avatar
artwork : thanks.
but will the WE topdeck work on the lipo chassis?
badboy is offline
Old 11-14-2010, 11:37 PM
  #10042
tommi's Avatar
artwork : thanks.
Yes, a direct fit.
tommi is offline
Old 11-15-2010, 06:56 AM
  #10043
does any body run 44mm drive shafts in the rear of their 416x? does it make any difference over the standard 42mm? i have heard a longer drive shaft can give abit more traction?
Smartypants is offline
Old 11-15-2010, 07:04 AM
  #10044
artwork's Avatar
Most of us run 46mm in the front and 44mm in the rear. For the most part I am more concerned about how the end of the shaft fits in the outdrive. In the front the 46mm helps to reduce spool cup breakage by sitting further into the cup. I am not sure I have ever really felt any difference in traction. This car has alot of traction naturally, so I am not sure you would really need anymore. The key is to understand what the setup needs for your driving style. I am not a big fan of running team setups, but they can provide the correct place to start for any driver.
artwork is offline
Old 11-15-2010, 09:23 AM
  #10045
Trader Rating: 35 (100%+)
I did a search on this thread looking for information regarding springs (over 20 pages), but I still need help (with springs ).
Questions:
1.) other than Tamiya, which manufacturers springs are a direct fit to my 416x shocks?
2.)I see suggestions referencing 19.5 spring stiffness, but I don't know which springs fit and have that stiffness.
3.)Is spring length important?
Tamiya has Red, Yellow, Blue, and White springs and they are available in "short" and a standard length??? Tamiya has a white spring set with red, yellow, and blue dot indicators. Tamiya has a black set with red, yellow, and blue dot indicators. Tamiya has a milky blue set with red, yellow and blue dot indicators. Are these all basically the same just in different colors?
Is there any advantage to using a short spring over a long spring?
Maybe we just need a tool for measuring spring stiffness.
Geppetto is offline
Old 11-15-2010, 09:27 AM
  #10046
Questions:
AE springs should be a direct fit (I always ran tamiya shocks on my TC5 using AE springs w/o issue). Xray springs work as well, but you need the Xray retainer.
An AE gold spring is 19lb. And yes, all those different Tamiya sets are the same rate, just different looks.
Old 11-15-2010, 10:30 AM
  #10047
CraigM have if you can put the picture of the problem that gave you the smokem
oscargonzalez is offline
Old 11-15-2010, 10:47 AM
  #10048
Thanks Mike. I'll take a look at the AE site. Hopefully, they provide published specifications for their springs.
Maybe someone else can address the importance of spring length???
Geppetto is offline
Old 11-15-2010, 12:21 PM
  #10049
Johnny Wishbone's Avatar
If you have 2 springs rated the same but different lengths they should function the same, as long as the short spring does not compress so much that you run into coil bind issues. (The spring is so compressed that the coils touch and no longer allow for any compression.) Hope thats the answer you where looking for.
Johnny Wishbone is offline
Old 11-15-2010, 12:32 PM
  #10050
JasonC's Avatar
Trader Rating: 120 (100%+)
i know this is not the for sale form, just figured i let you tamiya guys know first. i have a Brand New in Package Blue Tamiya Pit towl, that i have no need for, if you intrested please send me a PM
JasonC is offline
